Valvetrain Noise
Old Jul 4, 2021 | 07:43 PM
KK560's Avatar
KK560
Originally Posted by 60Gunner
If it just started the past 50 miles but good for the first 1000, I'd check to make sure a jam nut on one or more of the pushrods hasn't worked loose. If so, readjust and lock down.
Did you use red loctite? Some do.
Just got done re-checking and they were still tight. I have the back lifted up and was turning the engine with the tire and can still hear a clunk even with the rods loose.
Old Jul 4, 2021 | 07:45 PM
KK560's Avatar
KK560
Check for a collapsed lifter.
What do you mean by collapsed?
Old Jul 4, 2021 | 08:14 PM
KK560's Avatar
KK560
On a 99 TC, did you plug the hole in the cam plate?
The oil hole to the tensioner? Yes I did. The kit came with cover plates.
Old Jul 5, 2021 | 09:28 AM
Max Headflow's Avatar
Max Headflow
Is it the holes to the softail balancer tensioners or the holes for hydraulic cam chain tensioners? IIRC it's about 1/4" and takes a self taping screw. Cover plates sound like cam chain tensioners.
Old Jul 5, 2021 | 10:02 AM
djl's Avatar
djl
This is what Max is talking about.
Old Jul 19, 2021 | 12:37 PM
KK560's Avatar
KK560
Got the noise figured out. The bolt to the outer cam gear was coming loose. Still having problems with the speedometer needle and engine light coming on and off. Thanks for all the help so far.
drumdon
Engine Mechanical Topics
Aug 17, 2020 08:43 AM
bspencer
Dyna Parts
Oct 7, 2014 09:05 AM
hucks 08
Sep 23, 2010 10:57 PM
harris48cars
Touring Parts
Jul 8, 2010 11:27 PM
FLAMED96
May 7, 2010 09:41 PM
