Twin Cam Engine noise
Old Jul 19, 2021 | 10:46 AM
tinymike66's Avatar
tinymike66
Default Twin Cam Engine noise
Hi all.
so I just can't seem to find where I'm getting noise.
This is a fresh build, engine now broken in and it's so noisy
To describe it, sounds like , when u put a stack of money in a money counting machine with a slight tick too.
Happens most at lower gear 2000 to 3000rpm and quiets out when I shift to higher gear and either below 2000rpm or above 3000.
I've switched out pushrods to solid ones
I've double, triple and quadruple checked clearances
I've had crank redone with s&s pin, pro plugged and welded
rocker boxed grinded to ensure over 50thou clearance for springs
pistons to valve clearance was over 100thou
Had the cases on cam side ground down for cam clearance
s&s lifters
I'm completely baffled
I've taken this engine apart couple times to find issues and there's nothing I can see that would cause this
I have a daytona twin tec module
98" build
Woods tw6h cams
Can this be a case of ...you got a noisy engine?
Only thing that wasn't replaced were the rockers and rocker assembly as they appeared to be in good shape
Frustrating a lot of hard work, research , advice from you guys on here and doing everything proper way.
Anyways...anyone got any ideas , I more that appreciate your thoughts
Cheers
Old Jul 19, 2021 | 12:07 PM
todd-67's Avatar
todd-67
From what you are describing as far as the noise and the RPM's where it is most pronounced I am guessing too much rocker shaft to arm clearance. Check out rocker lockers. They may help.
Old Jul 19, 2021 | 12:29 PM
djl's Avatar
djl
Post a video. With a new build, could be many sources for noise but describing the noise leaves too much to the imagination.
Old Jul 19, 2021 | 12:48 PM
tinymike66's Avatar
tinymike66
Ill have to post video next weekend
I only ride on weekends and its most noticeable when engine has warmed up or is hot
Old Jul 19, 2021 | 01:30 PM
ROCKOUT Rocker Products
Sponsor
Have a look around my website, might be just what you need.
Thousands cured
John @ Rockout
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Jul 19, 2021 | 03:04 PM
Max Headflow's Avatar
Max Headflow
It's likely the 6Hs but early tensioners or loose cam gears can make the noise worse.
You can try and bottom out the lifter and back off 1/4 turn.
Old Jul 19, 2021 | 03:22 PM
tinymike66's Avatar
tinymike66
I don't have adjustable
I put in solids. I know those cams have a hard ramp
I've heard some engines not often but some are just noise makers
I'm hoping that's the case here
Old Jul 19, 2021 | 05:45 PM
tinymike66's Avatar
tinymike66
How do I post videos?
Old Jul 19, 2021 | 06:28 PM
tinymike66's Avatar
tinymike66
Old Jul 19, 2021 | 06:29 PM
tinymike66's Avatar
tinymike66
https://youtu.be/MZFZTaBJ
