116 blew, 107 rebuild
Old Aug 26, 2021 | 10:13 PM
Max Headflow's Avatar
Max Headflow
Got one good cylinder today. Will setup to do 2 more. On extra in case I screw up again.
This one came out much better. The cylinder is gummy and leaves fuzz on the inside. Cleaning it with 240 grit make the measurements much better. Before aluminum fuzz was sticking to the gages and creating an error. Had to clean them off. I changed to a 1 inch boring bar with inserts set up for final cuts in the aluminum with a smaller nose radius.
You can see the breaking through the case Iron liner, different than the SnS cylinder.
Final cuts to the cylinder for the step.
Old Aug 27, 2021 | 05:08 AM
Jackie Paper's Avatar
Jackie Paper
I was told by the carbide insert people that the finish in you cylinder was caused by the material welding on the tip of the insert.
More coolant and surface speed helps but out of the question for that setup. A sharp with just a small radius hand ground MoMax high speed steel tool in a slotted steel bar maybe.
I'm not into big cu. In. Are you trying to produce something you can't buy commercially?
Am enjoying this thread however. Spent 46 years in that world from machines smaller then yours to those bigger then houses.
Best friend has a 1936 Harley. Still working there. He finishes the propeller shafting on the carriers. Still done with high speed tool steel.
Old Aug 27, 2021 | 07:36 AM
wfolarry's Avatar
wfolarry
Tap Magic for aluminum will make them cylinders look like chrome when you cut them.
Old Aug 27, 2021 | 09:10 AM
Max Headflow
Most carbides bits are setup to cut steel will gum up on aluminum. Dealing build up for sure but the inserts on the 1 inch bar cut aluminum pretty well. I'm using a cobalt steel short 1/2 inch boring tool on the sleeve step and the aluminum is still pretty gummy there with the steel bits.
You can buy 4 1/8 cylinders. You can also have the sleeves installed for slightly less. It's something I wanted to try.
Old Aug 27, 2021 | 09:11 AM
Max Headflow
I got some I'll give it a shot.
Thanks Larry.
Old Aug 27, 2021 | 09:34 AM
Jackie Paper
Yes, you are trying real hard... I'm enjoying it but not envious.... 88 cu in scares me now..
Old Aug 27, 2021 | 09:58 AM
Max Headflow
For me a 88 ci TC was under powered. This bike on the first build was 95 ci.. It should have stayed that way.. I still like a good running 95 ci TC. Put 60000 miles on a 2002 RK that way. I could build this bike back to stage 1 or even a hot 95. but figured I'd try a 107 as the cost would be minimal. It allows me to keep the heads and cams.
Old Aug 27, 2021 | 09:59 AM
Max Headflow
Very interesting build Max. I do know that the 9b carries a lot of area under the torque curve.. Especially in bigger cube motors..
So does the 625s, They are a wide LSA cam. I'll probably stay with them.
Old Aug 28, 2021 | 05:39 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I always thought the Narrower the LSA the sooner the torque would come on. The 9B is at 105* compared to the 625's at 108.75*
Old Aug 28, 2021 | 06:07 AM
QC's Avatar
QC
Watching. Being a machinist, this is GOOD stuff!
