107 Circlip Paranoia
Old Dec 27, 2021 | 06:21 PM
Longobard's Avatar
Longobard
Default 107 Circlip Paranoia
Good afternoon
my OCD has kicked into overdrive.
2009 FLSTC installing a Fuel Moto 107.
This circlip is driving me nuts. It fought me every inch of the way. Now it’s “in” but doesn’t look exactly like the others. The gap between the ends is a closer than the others.
above the the circlip in question.
above is one that I’m using as a reference.
paranoia or pull it out and do it again.
Thank you
Old Dec 27, 2021 | 06:42 PM
TwiZted Biker's Avatar
TwiZted Biker
Take a screwdriver and tap the top of that clip and see if seats itself properly. Doesn't look like the top popped in deep enough.
Old Dec 27, 2021 | 07:27 PM
60Gunner's Avatar
60Gunner
^This^ push on it a litt!e. It should seat if isnt.
Old Dec 27, 2021 | 07:55 PM
seehogs's Avatar
seehogs
Better safe than sorry
Take it out, throw it across the yard
measure the pin to make sure it is
not too long and use a new clip.
On early twin cams I used a copper
1/2" coupler that was ground down
to a sharp edge, to fit inside piston.
Well oiled and the clip installed inside at an angle
then pushed in with a socket
Old Dec 27, 2021 | 08:00 PM
60Gunner's Avatar
60Gunner
Yeah if you pull it out, I wouldn't reuse it. I had one on my sporty build I had to push on a little to finish seating it.
Old Dec 27, 2021 | 08:44 PM
Screamin beagle's Avatar
Screamin beagle
It's not seated properly and it's spring has sprung from being messed with one too many times. Get a new one or hate yourself later.
Old Dec 28, 2021 | 12:35 AM
Longobard's Avatar
Longobard
Thanks for the replies. I just looked and felt wrong. I did use the copper coupler method and 3 of the 4 went easy. I will definitely replace the circlip, its not worth the risk reusing this mean SOB.
​​​​​​The pistons are CP Carillo, do I need to order them specifically or will new HD circlip's suffice? I will call Fuel Moto in the morning and share what I learn.
The wisdom, support and knowledge here at HDForum's is second to none!
Old Dec 28, 2021 | 06:39 AM
prodrag1320's Avatar
prodrag1320
the one side isnt in all the way,push the w pin all the way against the other clip & just push the clip in the groove with a small pocket screw driver.
Old Dec 28, 2021 | 09:04 AM
wilburbill's Avatar
wilburbill
It looks like the circlip is bent/sprung I would get a new one. It's a bit tough on the fingers but I just get them started with my fingers then use a small screwdriver to push them in. Just don't pry on them because you will bend them.
Old Dec 28, 2021 | 11:31 AM
Longobard's Avatar
Longobard
Quick update
yep, it’s buggered and after this photo headed to the bin. The good folks at Fuel Moto are graciously sending me 2 for the low low price of free dollars.
I offered several times to pay and Jim refused to take my money. I know they are cheap, but it’s not their fault. That lies squarely with me. I ham fisted it.
I was waiting to do my suspension upgrades until the drivetrain was complete, but I’m on holiday, it’s snowing it’s **** off and I need something to do.
Circlip on left is CP Carillo and right is factory HD. There is a slight difference in gauge.
KingBowser
Apr 15, 2024 01:16 PM
tydaniels
Audio Systems
Jul 6, 2021 08:16 AM
stro1965
Apr 13, 2020 02:56 PM
HOG_0308
Jul 1, 2013 05:10 PM
