551 S&S cams
Old Jan 16, 2022 | 11:25 AM
heritage2's Avatar
heritage2
Default 551 S&S cams
I ran into a problem installing my 551 S&S cams . The motor is an 05 so the ball bearing in the cam support plate gets pressed in and then the front cam is pressed into the ball bearing . The new cam just slides into the ball bearing loosely with no press at all . I measured the end of the new cam and it is .003" smaller than the cam I took out . Has anybody ever run into this with these cams ?
Old Jan 16, 2022 | 12:17 PM
60Gunner's Avatar
60Gunner
That's because after '07 there isn't an outer cam bearing. Only inner and the cams just slide in on both ends. You're fine.
Old Jan 16, 2022 | 01:20 PM
jbarr1's Avatar
jbarr1
I wouldn’t call it fine at all. Different cams for ‘07 and later. What is the part number of the cam set you are installing?
Old Jan 16, 2022 | 01:34 PM
tdrglide's Avatar
tdrglide
I've seen 99-06 style cams press into the bearing somewhat easily but slide in loosely is wrong. 0.003 smaller not right
Old Jan 16, 2022 | 03:25 PM
djl's Avatar
djl
'05 motor, cams ride in outer cam bearings and bearings are a press fit on the cam nose; haven't done hundreds but have done a few and never saw a bearing that wasn't a press fit onto the cam nose. I use the oven/freezer method to install cam bearings on the cams and, in that condition, the bearings will drop on the cams but will usually tighten up befor full seating and require a deep well socket and a tap to seat. Several time have seen the bearings fall out of the cam plate which can be addressed by "peening" the inside bearing seat and applying a bit of green (bearing retention) Loctite.
I would be sending thse cams back to S&S.
Old Jan 16, 2022 | 03:33 PM
60Gunner's Avatar
60Gunner
There's a difference between loosely and not needing to press them in, yes.
I assumed he had the right cams and was concerned with not having to press them in. The older cams use the older style chain too and wouldn't work with the newer style.
Old Jan 16, 2022 | 06:37 PM
heritage2's Avatar
heritage2
The cam should be a press fit on my 05 .I just spoke to my supplier and they agreed to re-order the cams and send these back. Thanks.
Old Jan 20, 2022 | 07:05 AM
prodrag1320's Avatar
prodrag1320
his motor is a 05,no this isn't normal or correct.
carlmartine
General Topics/Tech Tips
Dec 3, 2021 09:14 PM
Daxcobra545
Engine Mechanical Topics
May 6, 2019 04:17 PM
Rhetor
Exhaust System Topics
Jun 29, 2011 04:43 AM
99dyna
Jan 28, 2011 09:12 AM
Exquzet
Apr 1, 2007 10:21 PM
