107 blew head gasket during dyno
Ive been away for a while finishing up my 96B - FM 107 project. Finding a qualified dyno operator led me to Portland (Latus HD). We agree to do the break in on the dyno after I completed the heat cycles.
Much too my enjoyment, she fired right up and didnt blow up in my face. Yep, a little noisy while the lifters pumped up. By the second heat cycle she purred right along.
Dropped the bike off after 8 or 9 heat cycles over a week and a half. Since they are 5 hours away I went about my merry business and would return in 2 days time.
Next came the dreaded call, Sir we have a problem .
Long story short, according to the tech who performed the work he had completed the break in and was about half through tuning when the front head gasket let go. I dont remember if it was during the 60% or 65% throttle run.
I proceeded to tear it back down and see how bad the damage is.
External view of the offending head gasket
Front cylinder head gasket (head removed)
cylinder wall
Front cylinder head
The tech seemed to think I may have buggered the torque sequence. All things are possible and ultimately I am the one who did the work and who will fix it. He hoped that none of the gasket found its way into the engine and simply following his exact steps torquing the head down after replacing the gasket I might be ok. He has not seen these photos yet.
I havent drained the oil yet (13 miles on Shell Dino) or pulled the rear cylinder head yet.
At this point I could use a little advice. Is the cylinder toast?
The only oddity was they only put 13 total miles on the motor. Seems low to have completed break in and be half through tuning already.
Any guidance would be greatly appreciated.
Popular Reply
Also note If you need your parts checked and resurfaced we'll take care of it for no cost and make sure everything comes out correct, this is an easy solution. Send an email to jamie@fuelmotousa.com and I will get you a return authorization and we can turn the parts around within one day once we get them.
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Studs look dry, should have been some grease on them when torqueing. Did you by any chance O ring the cylinder to head dowels?
Were the head and barrels checked for flatness?
Torque procedure?
Head gasket for the right size bore?
Seems to be a lot of carbon in the motor for 13 miles.
Maybe replace the studs on assembly ( and lightly oil the threads as mentioned above). Is it possible that ignition timing ( IE: knock sensor failure or ecu) ) played a part in this?Just wondering if the tech didnt notice it was pinging away and cylinder pressure went through the roof.
not a fan of doing break in on the dyno! although it might be just fine if performed properly.
I did NOT lightly oil the bottom (shoulder) of the head bolts! Again, definitely a mistake.
flatness I only gave this a cursory check (definitely a mistake) I would be interested in a precise manner to verify flatness. Anyone have a detailed accounting they would be willing to share?
torque procedure was per cometic. 9,14,35 then 42
The master tech gave me the following torque sequence. 9,15,20,25,30,35.40 & 42. Make sure I oil the threads and bottom of the head bolts.
when I showed up he wanted to talk to the engine builder and go over some things. I pointed my finger at myself and said Im the perpetrator. He grilled me on lots of steps and at the end, the above is what he came up with as potential missteps.
Gasket size. I can only assume Cometic is smart enough to put two of the same size (bore) gasket in a package. I did lay them on top of each other and when installed made sure none was inside the bore area.
My immediate concerns are twofold
- is the cylinder toast? I will complete the tear down tonight and post more photos
- The cylinder head carbon needs to be cleaned up before I (we) can accurately assess damage. Recommended cleaner and process?
details
2009 FLSTC
- Fuel Moto 107 bored exchange cylinders (new exchange)
- Fuel Moto Level B heads (exchange) manual comp release
- CP Carrillo 10:5-1 pistons (new)
- Woods 777 cams (new)
- SE 50MM throttle body & injectors (new)
- factory camplate
- Dynojet Power Vision w/ base map from Fuel Moto
I loaded the base map and proceeded to do the heat cycles. The only time she moved under her own power was to my mailbox and back making sure I had the clutch adjustment correct. I had also installed an Aim VPC while waiting on circlips.
I pulled 3 - 3.5 gallons of fuel out of the tank when I got home. She was full. And like previously stated only 13 miles logged on the odometer during tuning.
Ultimately this is my problem and my opportunity to learn more while fixing my mistakes.
thanks again and sorry for the overly long post (Im stuck on a webinar) and greatly appreciate the responses and guidance.
respectfully
Travis (Longobard)
Some tips;
The studs to case torque should be checked in case they backed out during disassembly, about 25 ft lb would do.
Run each head bolt down on the studs to make sure there is no boogered threads or binding.
Lightly oil the threads and the underside of the head bolt flange.
At the 14 ft lb torque step, mark all head bolts, at the final 42 ft lb step all marks should end up close to same amount of rotation, usually a little past 90 degrees, if they don't something is wrong.
I myself use a light spray of Coppercoat on every mls head gasket, regardless of gasket instructions, let it tach almost dry before assembly, never a problem,
Other than the gasket surfaces not being flat, about the only other things I can think of is that the gasket had some oil on it, something got caught between the gasket and surface during assembly or possibly the gasket was defective.
Maybe the cylinder studs are pulling? Like I wrote, the only time I've seen this was when a buddies 95 ci TC had faulty Nos relay. Head gasket similar but it was pretty immediate. Notice that the about 1/2 of gaskets is pretty torn up.
This is out there but maybe some how the ECU suffered a glitch that made it think the timing for the back cylinder was for the front? A real shot in the dark. Bad ECU? Loose coil wires, bad grounds.
