Mechanical drawing, X & Y coordinates, etc
Old Feb 2, 2022 | 11:54 PM
Crankee Yankee's Avatar
Crankee Yankee
6th Gear
Default Mechanical drawing, X & Y coordinates, etc
Hey all:
I'm looking to fabricate up some torque plates for an M8 @ 128" bore size. I have blanchard ground plates w unfinshed thru holes for diameters. I may have a local machine shop bore the holes for the cyl spigots, thru stud, dowel pin & tapped holes. I'm wondering if any of you fellow engine guys may have a drawing of the stock H-D stud hole locations, datums etc from the intended C/L of the bore? Even just X & Y coordinates would do, I have them for TC, evo & shovel but no M8. I can use layout fluids, transfer hole locations if needed but if i'm asking somebody to do it for me, i'd like to avoid any interpretation errors so intended locations would simplify... Thanks in advance!
Last edited by Crankee Yankee; Feb 3, 2022 at 12:17 AM. Reason: i fat fingered entr by mistake
Old Feb 3, 2022 | 12:07 AM
MedicineBow's Avatar
MedicineBow
Welcome to the forum.
Old Feb 3, 2022 | 12:15 AM
JustDave13's Avatar
JustDave13
X left right
Y fore aft
Z up down.. depth
And that's what I remember from my precision sheet metal days
Old Feb 3, 2022 | 12:23 AM
Crankee Yankee
6th Gear
Thanks for the welcome & more importantly Thank You for your service!
Old Feb 3, 2022 | 12:32 AM
Crankee Yankee
6th Gear
Originally Posted by JustDave13
X left right
Y fore aft
Z up down.. depth
Thanks for the intel but you might be misunderstanding my query. I'm familiar with the X, Y & Z axis movements. what im looking for would be the actual coordinates for the hole locations. Example: from C/L of bore the two pushrod side cyl stud thru holes would located @ X-2.500" & Z- 3.125". i hope that clears it up. Thanks!
Old Feb 3, 2022 | 12:36 AM
JustDave13's Avatar
JustDave13
Got it. Sorry I don't where you could get a blueprint (factory?) but if push comes to shove you could backwards engineer a known good part.
Old Feb 3, 2022 | 12:48 AM
Crankee Yankee
6th Gear
Thays my plan B. Gaskets would suffice as well & if i still had milling machines w DRO's i'd just find my own coordinates, & do the work in-house. I still use the plates i made years ago. if i resort to Plan B, it just opens up opportunity for errors/interpretations that id rather avoid.
Old Feb 3, 2022 | 06:18 AM
prodrag1320's Avatar
prodrag1320
email me at veetwinracing@hotmail.com and i can get them for you (i cant put pics on here,tried in the past,cant figure it out)
Old Feb 3, 2022 | 07:59 AM
Crankee Yankee
6th Gear
Thanks! & will do
2manytoys
Oct 27, 2011 11:46 AM
StreetPilot
May 9, 2011 10:16 PM
hdrider6305
Jan 15, 2010 11:51 PM
tattoofreaksb
Welcome Area Only
29
Nov 24, 2007 02:27 AM
