Loctite question
Old Mar 9, 2022 | 07:53 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Both require 250°C for disassembly.
Old Mar 9, 2022 | 11:01 AM
CoolBreeze3646's Avatar
CoolBreeze3646
Just don't use it as an assembly lube as was stated in this thread - lol
https://www.hdforums.com/forum/milwa...ease-help.html It was supposed to be a joke; however, not funny.
Old Mar 9, 2022 | 11:47 AM
Max Headflow's Avatar
Max Headflow
The concert I'd have for using LOCTITE 2701 is that it's low viscosity. I suspect that you want higher viscosity for it to stay on the threads..
Old Mar 9, 2022 | 11:53 AM
OakMountainRider's Avatar
OakMountainRider
Poor guy. Hope it was a joke.
Old Mar 9, 2022 | 11:55 AM
Andy from Sandy
I can assure you it stays on the threads. I have used it for securing the bolt on trike conversion I made. I used it after one of the swing arm bolts came loose.
OakMountainRider
Originally Posted by Andy from Sandy
LOCTITE 262 is designed for the permanent locking and sealing of threaded fasteners.
LOCTITE 2701 is designed for the permanent locking and sealing of threaded fasteners.
Hehe, yep, that's what I read somewhere, too. This is how informative it gets when you google for it.
Old Mar 9, 2022 | 11:57 AM
Andy from Sandy
It is on the Loctite data sheets available for each product.
In other applications if you only go by colour then green is recognised as a bearing fit to shafts.
Old Mar 9, 2022 | 11:59 AM
OakMountainRider
Originally Posted by 2500hdon37s
Loctite 262 has not been replaced, the seller probably just doesn’t want to do an exchange. The green loctite products I do believe are permanent. The red is just medium/ high strength.
I would 100% not use the green and just go pickup some 262 or 263 locally if you can. Most any auto parts or hardware store should carry it.
Thinking about that.
Old Mar 9, 2022 | 12:01 PM
Andy from Sandy
Red is certainly not medium strength if we are playing the colours game, that would be blue.
Old Mar 9, 2022 | 12:31 PM
Max Headflow
Yeah, I should have admitted to I've not used it.. Swing arm bolts have longer thread engagement and depending on the year either 1/2-20 or 7/16-NC threads.. One thing to know is that the crank gear bolt is only 5/16-18 and the bottom of the hole leads to the cranks oil passage.
