Complete engine gasket set
Old Sep 15, 2022 | 12:24 PM
Tallguy64's Avatar
Tallguy64
In order of preference from a long time bike mechanic,
OEM gaskets.
Cosmetic MLS series.
And last place James.
Nobody sells an all in one kit anymore but the cheapy one which you do not want.
Link below for the cometic one i was looking at that says it is a full kit.
C9748F
Old Sep 15, 2022 | 03:37 PM
Lunchboxx's Avatar
Lunchboxx
Originally Posted by Tallguy64
Can someone explain why i would choose a .030 or and .040 head gasket? is it because of valve lash , compression or something else?
By no means am I an expert but my understanding is the thinner gasket will raise compression slightly.
Old Sep 15, 2022 | 03:52 PM
Rounders's Avatar
Rounders
Yes. Harley is .o43. cometic o3, and James .036. at least years I saw. I did .03 on my builds. But I would be tempted to go .036 to keep compression down.
Old Sep 15, 2022 | 09:41 PM
TwiZted Biker's Avatar
TwiZted Biker
C9748F
Those all in one kits frequently are missing odds & ends like a critical seal or two the separate kits will have.
Old Sep 15, 2022 | 10:01 PM
Rounders's Avatar
Rounders
NOr the one I bought this year that I recall. Box full leftover junk
Old Sep 15, 2022 | 10:25 PM
tdrglide's Avatar
tdrglide
I used to use the James. 036 head gaskets back in the 90's. Little bump in compression was nice. Never any head gasket issues with them. Don't think MLS were available back then.
Last evo i did about 10 years ago i used cometic head and base gaskets and everything else including rocker boxes I used HD. But that bike had head work and cam
Old Sep 16, 2022 | 01:07 PM
hrdtail78's Avatar
hrdtail78
I would shop piece meal and compare the price. Do you need valve seals and other items? Then compare to a complete gasket kit.
Old Sep 16, 2022 | 05:26 PM
Rounders's Avatar
Rounders
I've had good luck finding old parts manuals cheap on eBay. Plus Ron's still has parts finder. Not sure if that will change with Harley cracking down on internet sales.
Make a list and bring it in. Tell them come back, ask to be labeled.
I do wonder if you are paying for convince. Engine kit is around $150. I usually reuse primary gasket
Old Oct 19, 2022 | 10:35 AM
Eastcoast Jim's Avatar
Eastcoast Jim
The compression bump is slight - It is to tighten up the squish for better turbulence & burn
Old Oct 19, 2022 | 10:57 AM
pgreer's Avatar
pgreer
I used Cometic on my 1994 EVO about 5 years ago and it's still bone dry.
When you remove the top end to replace gaskets, you need to check the studs to be sure none are coming lose. If they are, replace as needed.
When things are apart, you need to check the deck height of the pistons to determine if they are above or below the top of the cylinders to determine which head gaskets to use to achieve the proper squish band, which is the space between the top of the piston and the head at TDC. Ideally you want about .030-.035. It won't do much to raise compression, but it will help with flame travel and help to prevent detonation. If you want to raise compression, you will need to either change pistons or have the heads shaved about .060. I didn't see the mileage, but I'd also replace the rings and do a valve job and replace the stem seals while in there. If it were mine, I'd upgrade the cam and inner cam bearing too.
To check the deck height, clean the cylinder bases and case surfaces, and install the pistons and cylinders without rings or gaskets and lightly bolt the cylinders down. Rotate the engine until the piston for each cylinder is at the top and measure the distance above or below the top of the cylinder. Then add the cylinder base gasket thickness to the measurement to determine which head gasket to use to achieve the desired squish band. Once you have that information, if you know the cam in the engine, you can use BigBoyz calculator to determine static and corrected compression etc.
http://www.bigboyzheadporting.com/EVOComp.htm
Paul
gswells
Engine Mechanical Topics
Aug 15, 2020 02:43 PM
JoshFG
Oct 21, 2018 04:42 AM
ElectraRoadKing
Jun 7, 2016 06:42 PM
Torque1340
EVO
Jul 18, 2011 06:55 PM
Dirrt
Jan 21, 2010 07:13 AM
