Checking deck height on M8
Old Nov 22, 2022 | 07:37 PM
wilburbill's Avatar
wilburbill
Ok, after making a few phone calls I was not comfortable with the figures I came up with on deck height. Its kind of hard trying to hold a straight edge, feeler gauges and keep the piston at TDC. With no rings it wanted to back off TDC a couple thousands... Anyway I ordered a deck bridge. That made the job easier and more accurate.I also used a new base gasket and torqued the cylinder down. My original measurements were incorrect. The measurements with the deck gauge are .013 in the hole rear and .011 in the hole front. Just goes to show its best to have the right tool for the job.
Old Nov 23, 2022 | 02:04 PM
Colvinb's Avatar
Colvinb
Having the right tools is so important specially when we are talking fractions of an inch. Man, even .013/.011 still seems pretty far down in the hole. What size head gasket are you planning on using? I would want to see no more than .005 in the hole before adding headgasket thickness. At that I would slap an ideal .030 HG on it and have a quench of .035. For you with a .013/.011 youd be at .043/.041, thats not horrible but it isnt ideal either for a performance build.
Old Nov 23, 2022 | 02:47 PM
djl's Avatar
djl
I debated posting a comment similar to what Colvinb just posted but backed off remembering that the TC OEM head gasket is .045" thick and in stock configuration the later models, not sure on the M8, it was not unusual for the piston to be done mas o menos .007" below deck which the OP may have considered. Many stockers running around like that with no issues. Just sayin. I would still trim to zero deck and use a .030" head gasket but that's just me.
Old Nov 23, 2022 | 03:48 PM
Colvinb's Avatar
Colvinb
Oh your 100% correct running 40+ quench will likely have no issues, but you'd expect more carbon buildup and a lesser overall compression ratio. Like I stated not ideal for a performance build and if you got it all off already then might as well get them close to zero as you can to tighten everything up for a "better" build to take advantage of your high dollar parts.
Old Nov 23, 2022 | 04:13 PM
PureHybrid's Avatar
PureHybrid
Have you contacted Cometic about head gaskets? They make some fairly thin ones for the twin cam, so I had to peek at their m8 offerings and it seems .030" is the thinnest they list. Im sure they would be able to build a 2 layer gasket
Old Nov 23, 2022 | 11:19 PM
Max Headflow's Avatar
Max Headflow
Find a thinner base gasket.. Use an 030 cometic head gasket. IMO running 0.040 squish ain't that much of an issue.. Especially if you are going big bore on a M8..
Old Nov 24, 2022 | 09:33 AM
wilburbill's Avatar
wilburbill
I am using .030 Cometic head gaskets and .014 base. The cylinders are getting shipped out Monday to be trimmed down. Big Boys calculator shows right at 11:1 with a 89 cc chamber after the cylinders are trimmed. I sent my heads out to be freshened up and cc'd.
This is actually the second time around for this 124 deal. First time around it had a piston slap sound in the front cyl after a couple of startups. I tore it back down and did some checking and found some taper in the front cylinder. I sent the piston and cylinder in and they sent me a new cylinder. First time around I used some .010 base gaskets to get the deck height a bit closer. This time around I'm trimming the cylinders, freshing up the heads with some bowel work and cc/mill and having the pistons Line2Line coated. I have used Line2Line several times on some of my big block Chevy builds and it works slick.
Old Nov 24, 2022 | 10:56 PM
Colvinb's Avatar
Colvinb
sounds like you got it down and a good way forward. Good luck with this go around.
Inop
EVO
26
May 29, 2025 08:36 AM
2ndgenmarine
Mar 27, 2020 04:09 AM
EarlB
Milwaukee Eight (M8)
Sep 9, 2019 11:15 AM
hardheaded
11
Sep 5, 2017 11:23 AM
OneBlackFly
Dec 22, 2007 08:55 AM
