Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
What is the name of the gasket 'glue' to hold the gasket in place during installation? (It is not a glue, just sticky to keep the gasket aligned.) I think it starts with hydra .... Thanks.
depending on the gaskets you are installing, go to home depot and get some threaded rod that is the correct thread for the bolts you will use for the cover. Cut some threaded rod, and screw a couple into spaced holes. Install gasket, install cover and some screws to snug down, remove rod and finish tq all fasteners.
