Primary Gasket
Old Aug 21, 2008 | 08:41 AM
Bulldog21's Avatar
Bulldog21
Default Primary Gasket
I have a very small leak from my primary. I changed out the gaskets but still have the leak. Its only a drop or two every time I run it but I want it stopped. Being as the big gasket has only been on the bike for a month or so, can I reuse it? I'm thinking about putting some gasket sealant around edge of the cover this time. That should hopefully stop the leak. Any info in greatly appreciated.
Old Aug 21, 2008 | 08:48 AM
PastorTom's Avatar
PastorTom
I run into this alot.. Use a little non-hardening permatex along with the gasket. Make sure the surface is dry and oil free when ya do it.. Should solve the problem..
Old Aug 21, 2008 | 08:58 AM
Bulldog21's Avatar
Bulldog21
Thanks Pastor Tom, and do you think I can reuse the same gasket or should I go on and get another one.
Old Aug 21, 2008 | 09:28 AM
PastorTom's Avatar
PastorTom
If the gasket isnt torn or dinged I would re-use it.. But also depends on the gasket material... If it's not a metal (never seal anyway) gasket then sure..
The usual reason for the leaks is usually some sorta crud on the gasket sealing surfaces.. make really really sure there clean of all old gasket material and crud and stuff.. Don't goop on a whole boatload of sealant.. ya really don't need much and "more is better" doesn't apply here..
PT
Old Aug 21, 2008 | 09:31 AM
oldgeezer's Avatar
oldgeezer
Also make sure you make up the bolts in a crossing pattern, tightening each one a little at a time. You want the cover to bolt up square.
Old Aug 21, 2008 | 09:35 AM
PastorTom's Avatar
PastorTom
Ohh ya.. and what he said..
LOL
Old Aug 21, 2008 | 09:53 AM
doublenaughtspy's Avatar
doublenaughtspy
Yea - the owners manual even shows you the pattern. 5 bolts going clockwise from top , the pattern should be 1-4-2-5-3. Snug them down in that pattern and then torque wrench them in that pattern. It could be as simple as that. I'd give that a try before doing the permetex to see if it works. Permetex is just more goop to deal with when you change the primary fluid again.
Old Aug 21, 2008 | 10:19 AM
Da Gumpmeister's Avatar
Da Gumpmeister
Permatex #80062 High Tack, Non hardening. It is stringyer than all get out. But don't worry. Once you have the primary on, little lacquer thinner on rag, wipe, it comes right off, scoot looks good, leak relegated to the back 40. When it comes time to work on primary again, stuff will come off with lacquer thinner, and you cn reuse the gasket, yet again. (As long as you don't trash it.)
If the stuff will hold a panhead together, it will hold yours.
All the rest still applies as posted.
Old Aug 21, 2008 | 10:27 AM
oldgeezer's Avatar
oldgeezer
Not sure about the Dyna engine, but my TC88B has two post gaskets that are on the inside of the primary where the inspection cover bolts up. Might make sure these are in place as well before you button it up.
Old Aug 21, 2008 | 10:15 PM
MaxShovel's Avatar
MaxShovel
Default Yep
Sounds like good advice.... curious to see how it goes, G.
Inop
EVO
26
May 29, 2025 08:36 AM
Rusty Axle
Shovelhead
Oct 19, 2017 04:41 PM
Beppe
Oct 19, 2017 03:49 PM
LQQK_OUT
EVO
22
Jul 10, 2016 11:25 AM
OneBlackFly
Dec 22, 2007 08:55 AM
