Quality Gaskets
Old Oct 9, 2017 | 01:44 PM
Rusty Axle's Avatar
Rusty Axle
Default Quality Gaskets
Is any one gasket manufacturer better than another? I'm planning to order a primary gasket to replace the current one, which leaks slightly at the bottom rear.
Also, any favorite gasket sealants? I know it's a Shovel, but I'd sure like to stop the leak.
Old Oct 9, 2017 | 03:41 PM
V_twins's Avatar
V_twins
Yamabond or UltraGray as sealer, works great on the exhaust ports
Cometic gaskets are great
Old Oct 9, 2017 | 05:26 PM
johnjzjz's Avatar
johnjzjz
second
Old Oct 9, 2017 | 05:40 PM
TwiZted Biker's Avatar
TwiZted Biker
All my go to stuff also.
Old Oct 9, 2017 | 06:22 PM
Rusty Axle's Avatar
Rusty Axle
Great info - thanks guys!
If I'm just pulling the cover, do I only need the individual primary cover gasket?
Looks like there are Cometic primary kits with multiple gaskets and seals for $70 at JP Cycle. Cometic has the individual gasket at $33 on their site. If I need to consider any other gaskets when I pull the cover, I may as well go for the kit.
Old Oct 9, 2017 | 08:38 PM
feguy1's Avatar
feguy1
Get the kit, even if you don't use all of it, as a shovel owner, you should increase your gasket and seal inventory every chance you get.
Old Oct 10, 2017 | 07:10 AM
johnjzjz's Avatar
johnjzjz
to add to that we keep all of our gaskets in freezer zip lock bags to keep them as fresh as possible - bigger bags like a primary some come in re sealable bags
you can write on the plastic bag the OEM part number and what it fits
Old Oct 10, 2017 | 02:23 PM
Rusty Axle's Avatar
Rusty Axle
I appreciate the collective wisdom of the board ninjas... the full kit it is.
Old Oct 19, 2017 | 06:48 AM
scooper321's Avatar
scooper321
So I Googled these. Found UltraGray. Also found a bazillion things called Yamabond. Is there a specific version of YB that is best?
Also, can this stuff be used with any gasket (not including O rings)?
Old Oct 19, 2017 | 04:41 PM
johnjzjz's Avatar
johnjzjz
yamabond # 4 is all we use semi hardening and works on threads < best ever used
Loctite ultra gray the black one they sell is a adhesive type also a must have
gaskets / o ring threads - and worn out shafts like a farm tractor you can fill the back of a seal the spring lip let it dry 2 days it will seal a groove and not leak again as it make the seal tighter on the shaft
Inop
EVO
26
May 29, 2025 08:36 AM
Beppe
Oct 19, 2017 03:49 PM
RLH3175
EVO
13
Jul 9, 2016 10:08 AM
shortride
Mar 30, 2011 06:44 PM
Bulldog21
Aug 21, 2008 10:15 PM
