Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Hello,
I wonder if someone here can advice me about a tool to install the wrist pin circlip on my JE-Pistons. I can easily install the Harley clip with a screw driver, as it is thinner, but the JE-clips are pretty much thicker and I must have a tool. The thickness of the JE-clips are 0.073", whereas the Harley clips are thinner. See pic below: JE site says not to use a scew driver, but does not mention any tool.
I have a Dyna 2006 and the wrist pin is 0.927"
Best regards
Here’s what I’ve done to manage those aftermarket clips. 3/4 brass coupling from hardware store and a 5/8 long socket to drive it home. Works every time. I squeeze the clip w pliers and lube the brass first w some light spray lube. Position the gap to outside like pic and aim the gap to desired spot at the pin
Heres what Ive done to manage those aftermarket clips. 3/4 brass coupling from hardware store and a 5/8 long socket to drive it home. Works every time. I squeeze the clip w pliers and lube the brass first w some light spray lube. Position the gap to outside like pic and aim the gap to desired spot at the pin
Umm, Errr, Dave?.. I think that's a copper 3/4" sweat coupling...Not that i'm a plumber or anything... LOL...
I have made a tool out of the copper pipe dimensions available in my country and I have practised on the old stock pistons. However it did not work, as the tool deformed the clip. The OD of the copper pipe I used is 22 mm and the ID is 20 mm. That is too small.
The wrist pin hole in the piston is 23,55 mm (0.927").
I realise, by watching the video in the realated thread below, that the tool I made is too small in its inner diameter and that I need a pipe with a 24 mm OD and a 22 mm ID and then I would have to grind that end of the pipe which is going into the piston.
As I do not know if this will succed I simultaneously looking for other solutions.
Has anyone here tried this tool with the thicker JE and CP clips (0,073")?
I installed some JE pistons more than a few years ago. Part of an Axtell kit. I used a slightly modified awl and a bunch of cuss words to install circlips. Orientation of the clip opening was very important to get them in
