Rocker Arm Support Plate Bolts
Old Apr 9, 2023 | 02:16 AM
OakMountainRider's Avatar
OakMountainRider
Default Rocker Arm Support Plate Bolts
Hello,
As I assemble my Dyna 2006 I find no WASHERS to the Rocker Arm Support Plate Bolts. The manual states there are washers, but I can not find any. My bolts look a bit different to what is drawn in the manual. Do I then have a different type of bolts, not needing washers? Or have I put them somewhere? I am a bit confused, and I hope someone here can help me out.
From the manual:
One of my bolts:
Old Apr 9, 2023 | 07:00 AM
hrdtail78's Avatar
hrdtail78
There are no washers for that style of bolt.
Old Apr 9, 2023 | 07:11 AM
Iceman24's Avatar
Iceman24
That's a hex-washer, or flange bolt. The washer's built-in to evenly distribute the load...e.g. no washer needed.
Old Apr 9, 2023 | 07:59 AM
Rounders's Avatar
Rounders
One thing that delayed my last build was my rocker arms were worn, where the pushrod rides. Something you don't think about getting before hand. I ended up with one new set and one used set out of a evo.
Old Apr 9, 2023 | 08:48 AM
OakMountainRider
Thanks a lot.
Old Apr 9, 2023 | 08:49 AM
OakMountainRider
Thank you, Sir.
Old Apr 9, 2023 | 11:20 AM
OakMountainRider
Thank you, Sir.
Old Apr 9, 2023 | 11:29 AM
Weeboy1's Avatar
Weeboy1
not straying from the topic at all….
ROCKOUT Rocker Products
Nov 22, 2020 04:47 PM
Lambda
Engine Mechanical Topics
Sep 2, 2019 09:01 AM
Krazy8s
Apr 12, 2018 07:08 PM
Rumbles
Jan 8, 2016 04:53 PM
notarheli
Exhaust System Topics
Sep 10, 2008 10:20 AM
