M-8 114 to 117
Old Jul 15, 2023 | 05:28 AM
MCRD'71's Avatar
MCRD'71
Default M-8 114 to 117
Looking for butt dyno opinions from 114 to 117 with parts recommendations.
Thank you.
Old Jul 15, 2023 | 06:33 AM
TracerBullet's Avatar
TracerBullet
Following,
I’m curious to see what the difference is in 3ci
Old Jul 15, 2023 | 12:22 PM
Harley1004's Avatar
Harley1004
i’m subscribed
I’m not an expert buy any sense
However,
I don’t think you’ll notice too much
Unless you went to
A lot higher compression
Cam upgrade
And head work
At that cc
Upgrade
I think you will notice
A nice upgrade with what you have already.
With A stage two cam upgrade
Exhaust upgrade
And then intake
air box upgrade
and tune with what
you have already
Just my opinion
And I’m out…..
Old Jul 15, 2023 | 01:33 PM
Sweep'r's Avatar
Sweep'r
Stock 114 is at 10.5:1 compression, stock 117 is at 10.25:1...most kits put over bores at 11:1, will you see corresponding differences, sure, nothing earth shattering. Stock 114 shares a cam designed first for the 107 so going to a 117 without a cam change will not give anything you're looking for. As mentioned, a stage 2 will be the biggest change, and then going to a 117 or stage 3 will give some extra but not the same big bang for the buck as the stage 2
Old Jul 15, 2023 | 03:38 PM
TriGeezer's Avatar
TriGeezer
The biggest bang for the buck is a good cam. 3 ci…will not be noticeable.
Old Jul 15, 2023 | 03:50 PM
NorthWestern's Avatar
NorthWestern
Must be a buddy's take-off parts from a big bore upgrade? Hoping so, if you are actually spending the dough to do this new, I would look at other available options.
Old Jul 15, 2023 | 04:40 PM
MCRD'71's Avatar
MCRD'71
Default 114/117
New take off parts.
Old Jul 15, 2023 | 04:42 PM
MCRD'71's Avatar
MCRD'71
Default 114/117
30-30 Cam
wjcbsr
The Dyno Room
20
Feb 14, 2025 03:57 PM
Tom Sanders
May 27, 2022 09:13 AM
cruzinthecoast
Feb 22, 2010 08:37 AM
SC-Longhair
Oct 11, 2009 11:42 AM
but Ill try 2 try
May 31, 2006 06:52 AM
