84 low rider non cv
Old Jul 23, 2023 | 02:28 PM
Steve1616's Avatar
Steve1616
Default 84 low rider non cv
Helping a friend with 84 sporty, been sitting for quite a while, went to crank over and yee haw oil spewing out of carb, sounds like a top end rebuild to me, maybe whole motor rebuild to be safe???
Old Jul 23, 2023 | 03:04 PM
davekp's Avatar
davekp
Need more info.
Mods?
How long did it sit?
Past history?
Need to do more diagnosing before jumping into a rebuild.
Old Jul 24, 2023 | 09:17 AM
Steve1616's Avatar
Steve1616
Not sure on how long it sat, probably a few years, was also told sluggish when it was riden, the oil just gushed out of the carb. Will get more info on how long it sat. going thru the service manual got the impression that the non cv is troublesome when it has sat for more than a year, wasn't even started to let run
Old Jul 24, 2023 | 04:40 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Oil has drained down into the crankcase, just start it up and point the breather hose into a pan.
The engine will scavenge the oil back to the tank, and what it can`t scavenge it will barf out the breather.
No panic.
Old Jul 25, 2023 | 06:28 AM
Steve1616's Avatar
Steve1616
Was looking again at service man gotta check and see if there might be a clogged line as well,
thanks guys for the input
Old Jul 25, 2023 | 08:47 AM
bustert's Avatar
bustert
engine badly sumped. might have to pull the oil pump to drain it. i think by 84, hd did away with the plug on the flywheel case but if it is there, treat it with caution, seen some guys totally screw up some cases.
to pump that much oil with just the started will be hard on it, so go SLOW and allow plenty of time for it to cool!
Old Jul 31, 2023 | 12:35 PM
Steve1616's Avatar
Steve1616
Oil not coming out through the intake of the carb, coming from breather, clogged return line????
Old Aug 2, 2023 | 11:38 AM
Yankee Dog's Avatar
Yankee Dog
The harley is a dry sump engine.
It's as previously mentioned. Oil has leaked into the crankcase from the oil tank. By design, the crankcase does not store any oil in it like jap (we sump engine) bikes. When oil leaks past a check ball in the oil pump (from sitting any length of time) it drains into the crank case where it has no room, so when starting, it pukes oil out the breather hose. Totally normal. Played this game every spring with my sporty.
Just makes a mess and you need to replace the oil that was puked out. Often, newbies will check the oil level before starting, notice that the oil is really low in the oil tank, add more oil, then start bike. It then pukes all that excess oil (along with the original sumped oil) out, making a mess.
CamCollins1022
Shovelhead
18
Oct 31, 2022 11:44 PM
harleymike151
Feb 20, 2017 08:50 PM
biker01
Shovelhead
Mar 11, 2008 01:59 PM
kevinb62
Dec 12, 2006 12:55 PM
