Thoughts on Feuling 543- Twin Cam 96
Old Aug 23, 2023 | 02:20 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Originally Posted by 04FXDI
@98hotrodfatboy
Wanted to resurrect this......what makes the 525 "lame."? I'm in need of an education.
I contacted Feuling and they said the 525 is a very good cam for my 95" build because of my riding style.
The 525 wakes up around 1750ish and carries out to 5500. But I never push my bike past that and I like
the way she pulls now. What other cam can give that low end and carry out that far? I'm interested
I get involved in a lot of builds and I can't just say off the top of my head but I will have to go back through yours and the reason why I said what I said and match the cam to whatever the needs are... I just don't throw information out there without doing the research. So if I said the 525 was lame it was probably because I looked at its ramps, lift
@ TDC, lobe separation angles,, everything.. I know how cams react to certain compressions.. BUT if you want me to look into yours further I will.. Everyone has their own style and their opinions based on their experiences of what they've done with builds and how to move air at what RPM etc..
​​​​​​ What I'm getting at is the 525 would not be one of my choices but there's an *** for every seat and if it fits what you want that's great..
Old Aug 23, 2023 | 02:43 PM
98hotrodfatboy
deleted...
Old May 27, 2025 | 02:55 PM
Bam63's Avatar
Bam63
6th Gear
Default That sure was wrong.
Originally Posted by 60Gunner
It will fall flat on it's face below 3500 rpm at stock compression of a 96. Wouldn't be able to pull itself down the road yet alone you. Best look.for a cam with an IVC no later than mid 30s.
I have the mentioned cams and have had for about 3 yrs. I also have darkhorse motor sprocket ciro air cleaner factory head pipes with some cheap slip ons. This thing runs. Sounds good and I haven't ran up on to many bikes that can run with it wit the same upgrades. I was amazed at the power. Your right about below 3500 but keep it above that.
Abadrs
Twin Cam Motors
Aug 24, 2021 05:38 AM
LaLleguaNegra
Milwaukee Eight (M8)
79
Jul 20, 2020 10:13 AM
Glenvillle
Engine Mechanical Topics
42
Feb 13, 2019 07:05 AM
grummie
Mar 8, 2017 01:49 AM
huffhuff
Jul 19, 2006 02:20 PM
