Valve spring noise?
Old Aug 16, 2023 | 02:31 PM
Z's Avatar
Z
Default Valve spring noise?
If I place my engine under heavy load at lower RPMs - say 3,000 below - I consistently hear a noise that I have thought was knock, but I'm beginning to think might be more valve train related..
The sound is like what you might expect to hear what a large spring under tension is cut, that sort of twangy sound. It's not a classic sound of knock
When I had the engine built, I know the builder installed heavier springs that's really all I can remember about them.
Does this sound like a spring issue, or can knock make a sound like I described?
At higher RPMs when I crack the throttle I don't hear the noise, only when I'm in lower RPM ranges.
Thanks in advance for sharing your knowledge
Old Aug 16, 2023 | 02:50 PM
2500hdon37s's Avatar
2500hdon37s
I would be more inclined to think along the lines of your compensator is what's making the noise.
But I wouldn't expect that below 3000rpm, but I would at less that 2000.
Old Aug 16, 2023 | 04:05 PM
Z's Avatar
Z
@2500hdon37s Damn, I never thought about the compensator being the source of the noise.
Just to be sure though, the noise sounds like a spring under tension being cut - that twang sound - and it persists until I back out of the throttle (which I do instantly), and seems only to happen at lower RPMs (SUB 3000). You're saying this is a typical failing compensator sound?
Old Aug 16, 2023 | 04:37 PM
djl's Avatar
djl
Harley's make lots of sounds but "twang" is a new one. OP says motor has been "built" but leaves out build details and whether or not the build was tuned. I would want to know those details before suggesting the source of the "twang". I will say that putting the motor under heavy load below 3000 rpms is not a good idea.
Old Aug 16, 2023 | 05:22 PM
Z's Avatar
Z
It's a strange one, I know.
Buold details are in my signature but I'm glad to reproduce them here:
S & S 100 inch 10.5:1 kit + 570 easy-start gear drive cams, ported heads with 0.060" over intake valves, Thunderheader 2-1 exhaust, Arlen Ness Big Sucker air filter, ThunderMax ECM.
When I say heavy load what I really mean is, If I'm rolling along in the 2000 to 3,000 RPM range, and I roll onto throttle more than slowly and carefully until I get through that range, I hear that sound. It's absolutely more pronounced when hot.. I don't know if that helps. The timing curve loaded into the bike it's from a similar biuild and obviously with the ThunderMax the air fuel mixture is automatically tuned (I installed O2 sensors in both of my pipes)
Old Aug 17, 2023 | 09:13 AM
djl's Avatar
djl
My bad; I was responding to your first post and missed the build details in your second post.
Your description of the sound as a "twang" doesn't fit the noise generated by detonation but the conditions under which the noise presents indicate, to me anyway, that detonation may be a source of the noise. The fact that the noise presents more pronounced when hot and having to baby throttle to get through the 2K-3K range and the fact that the timing curve is from a "similar" build all point to detonation for me which would present like littel ball bearings bouncing around in the combustion chamber. I don't know anything about the TMax but from what I have read, tweaking timing to be compatible with the build requires manual inputs but, like I said, I know nothing about the TMax.
If I were in your situation, I would get the bike on a dyno for a proper tune focused on the timing curve.
Old Aug 18, 2023 | 01:15 AM
Z's Avatar
Z
Interesting theory fhat's simple enough to prove/disprove by taking away some timing in that RPM range + throttle position range.
I've had too many bad experiences with dyno time to want to throw any more cash in that direction.
Old Aug 18, 2023 | 08:45 AM
djl's Avatar
djl
Originally Posted by Z
Interesting theory fhat's simple enough to prove/disprove by taking away some timing in that RPM range + throttle position range. I've had too many bad experiences with dyno time to want to throw any more cash in that direction.
You can try that and if it proves that detonation is the source of the noise, find a reputable tuner; get the motor tuned properly. Detonation will kill a vtwin pretty quick.
Erythorbate
Sportster S
Jun 8, 2022 09:32 AM
troop8520
May 3, 2013 12:35 PM
sioux565
Jul 19, 2011 07:57 PM
1peter
Jun 5, 2009 11:10 PM
Custom07RKC
Mar 12, 2007 11:20 AM
