Milling TC heads
Old Oct 31, 2024 | 08:50 PM
Adam76's Avatar
Adam76
Default Milling TC heads
Hi,
can anyone please tell me roughly how many thou off the heads 1cc equals?
In other words, if I mill the heads down 2cc (from say stock 85cc to 83cc) how many thou off would that equal?
thanks
Old Nov 1, 2024 | 04:20 AM
eighteight's Avatar
eighteight
.007 off = 1cc
Old Nov 1, 2024 | 05:59 AM
Adam76's Avatar
Adam76
.007 off = 1cc
Thanks
Old Nov 3, 2024 | 07:48 AM
Sweep'r's Avatar
Sweep'r
I'd want to have them cc'd to see where you're really at, may need more off of one than the other
...or maybe run a .030" head gasket instead of .045"
...piston depth in the hole vary from cyl. to cyl. ?
Old Nov 5, 2024 | 10:37 PM
Adam76's Avatar
Adam76
Yes, all valid points to do it properly.
Thanks
Old Nov 13, 2024 | 06:37 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Also, if you decrease the overall height of the rocker assemblies by milling the head .014"-.021" plus reducing the head gasket thickness by .015" I would recommend adjustable pushrods..
Old Nov 13, 2024 | 06:52 PM
Adam76's Avatar
Adam76
Yes, I would probably use adjustables.... But from what I understand - stock PRs use about .100 of the .200 travel available. So wouldn't an extra .030 / .035 with the stock PRs still be within acceptable limits?
Old Nov 13, 2024 | 07:03 PM
98hotrodfatboy
Yes they would..
samrugger
Jan 20, 2024 02:54 AM
AtticusFinch
Oct 9, 2017 08:33 AM
Tltrump
Exhaust System Topics
Dec 28, 2007 06:04 AM
tiiiim2
Jan 20, 2007 10:14 PM
