Pistons and cylinders
Old Jan 11, 2025 | 05:09 PM
Rpaulickjr's Avatar
Rpaulickjr
5th Gear
Default Pistons and cylinders
Here’s some pics of pistons and cylinders, revolution performance 98 domed kit, cylinders new last year, pistons cleaned twice and reused, no oil in the intake but had a small head gasket leak so that’s why I tore it down to rebuild and use some screamin eagle parts, new cylinders and forged pistons, only had 7000 on this build, so where does all the carbon come from? Bad oil ring and scratched the pistons so they don’t burn it off? I’m baffled here, heads were redone 18000 mile ago, small bit of red in the cylinder too, had this issue since the first build and the pistons got reused every time so maybe the pistons are just ****
Old Jan 11, 2025 | 05:58 PM
Jackie Paper's Avatar
Jackie Paper
Did you measure pistons in the proper area for clearance and ring gap.. Appears you have a clearance issue along with not enough ring gap.
As it got hot, rings butted and went out of round. Caused the scratches. They indexed around slightly as they all do from cross hatching.
Cross hatching looks too fine to me to for a rebuild. However, if done on good equipment and a perfect bore job, the cross hatching can be like that.
I have seen cylinders on small 4 cylinder Honda car motors that looked like hydraulic cylinders.
Just an opinion.
Old Jan 11, 2025 | 06:04 PM
Rpaulickjr's Avatar
Rpaulickjr
5th Gear
That’s definitely possible, I gapped them
about 3 inches down in the cylinder, also has some scratches on the pistons from cleaning I tried to sand out so that didn’t help either, it’s all being replaced but I don’t want a repeat of this so where should rings be checked at? I went .017 and .019 on the gaps last time, so maybe go wider this time if they aren’t pre gapped, it’s a se kit this time so they may be gapped already and they run a tighter piston to wall clearance compared to the revolution kit
Old Jan 12, 2025 | 04:19 AM
buell95's Avatar
buell95
Are these niksil cylinders?
Old Jan 12, 2025 | 05:39 AM
Jackie Paper
Cylinders should be round and the same size. That's how they are when bored with good equipment with the cylinders properly clamped and torque plates.
The hone is just for cross hatching finish.
If cylinders are correct, should not matter. Measure them. I use inside micrometer. Now it's not calibrated. I use my outside micrometer to actually get a size from the inside micrometer.
If your checking a ring gap on used cylinders, check it at the bottom in the unworn area. Remember, any wear areas after finial hone sould not be over allowable wear tolerance.
And if you are near wear tolerance, engine life will be short. And noisy.
Usually, wear is greatest just a little way down from the top.
Remember, most pistons are cam turned and have a certain area to measure OD. On used, that area will show plainly.
You need measuring tools even if all you are doing is the finial assembly,
Old Jan 12, 2025 | 08:08 AM
bustert's Avatar
bustert
i never trust ring gap from the box. i usually buy first over size and set gap at the tightest allowable, but the grinding must be done right.
pistons are not true round and sizing is done at the shirt level 90* from the pin.
ring are set gaps 120* apart on the gaps.
bore needs to be measured in several places going down.
pay attention to rings, bought a 1975 fxe for a song and a dance since the guy rebuilt it himself and installed the rings upside down and it smoked worst than before the top end.
rings will rotate in the pistons when running at a very slow rate.
did you check land clearance???
carbon can come from several sources and is normal even with unleaded fuel.
lack of lubrication on start and fuel wash.
many sources so you must back track, reason why i keep a log of all measurements and such.
also of note, some pistons are treated and reusing them can bring issues as the surface area is worn or altered.
Old Jan 12, 2025 | 08:09 AM
Rpaulickjr's Avatar
Rpaulickjr
5th Gear
Ok, I will definitely get an inside micrometer to measure when I check these rings, this new kit is a se kit from suburban speed which is a Harley shop that does the king of the baggers bikes, new cylinders with fresh bore and they say the rings are gapped and just need to be checked, when I did them last time I just took revolutions word on the 3.93 bore size, but didn’t account for the nikasil coating in the bore, that coating breaks down fast as you can see in the cylinders, I gapped rings based on the size listed on the bore and may have been a little tight, thank you again
Old Jan 12, 2025 | 08:20 AM
Rpaulickjr's Avatar
Rpaulickjr
5th Gear
i will definitely check these at a few spots when I assemble it, and wash multiple times, the pistons may have also been coated to go with the nikasil cylinder coating and I damaged the coating cleaning them, they probably should have not been reused, being that I had this issue 3 times I went with a se kit this round, some of the crust is also connected to the revolution kit wanting marvel mystery oil put on the pistons and rings for assembly and possibly got burned to the tops of the pistons at break in when they had some scratches from cleaning and the coating being gone, land clearance is good as we didn’t change the stroke and height but revolution does have a slightly different wrist pin height, we also went with a thicker head gasket this time because compression was too high with the last kit and was hard to get 93 octane gas on road trips
Old Jan 12, 2025 | 09:42 AM
Jackie Paper
Niksil is for aluminum cylinders. Why would you put it on a steel liner like Harley has?
Old Jan 12, 2025 | 01:16 PM
djl's Avatar
djl
So much going on with the OP and the original build and his plan going forward it is useless to try and figure out what went wrong with the first; so many things that could have caused the problem.
Going forward, new cylinders and .010" OS pistons and having cyliners bored, pistons fitted and rings gapped by a professional machine shop that has provided this service is the best way to be sure the top end will be correct. Send the cylinders, pistons and rings to a shop, like Hillside Cycles, BigBoyz, VeeTwin Performance, etc. At least have the valve guides and seals inspected and replaced if necessary. Get the new top end to a competent tuner for break in and tune. This will leave "operator error" as the most likely reason for another screwed up top end. i.e. cleanliness and proper assembly
