Four drain plugs...??
Old Jan 27, 2025 | 04:35 AM
Cowboy0727's Avatar
Cowboy0727
Stage I
Default Four drain plugs...??
Can someone tell me why I have four separate drane plugs on my 1994 Harley Davidson Dyna custom lowrider?? I know about the transmission drain plug and one oil plug and also the chain case plug but I have one more plug it seems like it has oil in it all so... If necessary I can post a picture. Thanks
Old Jan 27, 2025 | 05:42 AM
Jackie Paper's Avatar
Jackie Paper
That one is not supposed to be removed if your referring to the one with tapered threads. Use a tapered pipe sealer on it and use care to not over tighten it.
You have a transmission drain, the actual oil sump for engine in the pan under the transmission and the primary chain and wet clutch oil drain.
And yes....
PS..Welcome to the HDFORUM.
Old Jan 27, 2025 | 06:34 AM
CoolBreeze3646's Avatar
CoolBreeze3646
1. If you are going to work on your bike, get a HD Service Manual for your bike.
2. Read it.
3. Report back on your findings once read and comprehended.
NOTE:
The above information, while credible, is worth what you paid for it and should not be considered gospel.
Do due diligence, research and have a H-D Field Service Manual before working on your bike.
You will probably have many opinions and suggestions presented; make sure you research the person providing the helpful information as there are some who provide good information that is useful and some who speak out of other orifices with gibberish. You will figure out this quickly.
Old Jan 27, 2025 | 07:19 AM
Yankee Dog's Avatar
Yankee Dog
Please post a pic or two...
Old Jan 27, 2025 | 07:34 AM
702's Avatar
702
You don't.
cyclepath37
EVO
Apr 4, 2014 08:33 AM
hardheaded
May 25, 2013 06:25 PM
darylnj
EVO
Jan 4, 2013 07:07 PM
mikes4692003
Aug 11, 2009 05:50 PM
west texas
Jan 12, 2009 09:08 AM
