Leak down test
Old Apr 11, 2025 | 10:21 PM
Since 1968's Avatar
Since 1968
The one and only time I did a leakdown test I managed to stop the pistons from moving by sitting on the bike with one foot on the rear brake. I like the locking bar idea and testing in several piston locations.
Old Apr 11, 2025 | 11:10 PM
Lonewolf176's Avatar
Lonewolf176
Jims also makes a tool. $$ but locks the flywheel in any position.
https://www.zippersperformance.com/758-753/
Old Apr 12, 2025 | 12:08 PM
djl's Avatar
djl
That's the one I use.
Old Apr 14, 2025 | 09:41 AM
Fat11Lo's Avatar
Fat11Lo
I have that one
Now if they would make any for the M8 again I'd Be happy
Old Apr 14, 2025 | 10:40 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
A leak down test is a good diagnostic test to see the condition of the seal of the rings and the valves.
A compression test is not sufficient. With a compression test a cylinder may have "good" compression, but it does NOT tell you if there is a bad valve seat seal.
Here's a video on how to do a Leak-Down and what the results indicate.
Kevin
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Apr 21, 2025 | 12:18 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Kevin
If a cylinder has a bad valve seat seal, it will have low compression, and the engine must be disassembled and repaired.
If a cylinder has good compression, there is no need to look further.
And in the case of the original post in this thread (where there was no problem to begin with) there was no reason for a compression check or a leakdown test.
If an engine is performing well and not burning oil, leave the compression tester and leak down tester in the tool cabinet.
The FAA does not require leak down tests every 100 hours on motorcycles...
djs
Milwaukee Eight (M8)
32
Nov 27, 2021 05:30 PM
Mhoffer
Mar 3, 2018 11:06 AM
Ironyman
Ironhead
Oct 18, 2014 02:55 PM
Mike in Oregon
Jul 2, 2010 06:57 PM
2002bigbored
Jul 27, 2008 06:47 AM
