Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Is there a difference between a Rockout and a Rocker Locker? They look to be basically the same product produced by different manufacturers.
The Rocker Locker comes with an alignment centering tool.
Rockouts are my original PATENTED solution for the top end tapping problem. Thousands cured worldwide!
Have a look around my website for more details.
__________________________________________________ ____ For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
