Is this the dreaded sumping
Old May 15, 2025 | 07:57 AM
red shift's Avatar
red shift
Default Is this the dreaded sumping
I have a 2019 117CVO FL that I bumped to 128ci a few years ago, new plate, pump, cam and heads. Its been running like a raped ape for the last 25k miles.
I pulled the sump plug while doing an oil change (having warmed up the motor) at the weekend to see about 600ml (20floz) drain from the hole, un-airated no bubbles or froth.
Its an S&S pump on a 3tho runout so you'd hope its scavenging ok.
It's already got vented dipstick, trans cover and head breathers vented to atmosphere
I plan to check:
  1. Leakdown (pushrods off to check all points of the stroke), If suspect inspect valves and rings, new rings in hand so will probably replace and set closer to 'race'.
  2. Cam chest and pump etc
  3. Breathers (new Feuling set in hand)
  4. Oil return lines
  5. Cam chest check valve replace
  6. Sump plug replace (Feuling in hand)
  7. Piston oilers (they were replaced on the rebuild with pressure-tested and surfaced sets on Cometic gaskets as the S&S versions weren't released at that time) test and replace with S&S
Have I missed anything?
David
Old May 15, 2025 | 08:04 AM
cobra23's Avatar
cobra23
Seems that if it was sumping you'd have the associated power loss. Plus you have an S&S oil pump which eliminates any stock harley pump issues.
But you should talk with a trusted mechanic and discuss your concerns.
Old May 15, 2025 | 09:14 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
David
Well, the latest design OEM oil pump will pump enough oil and will eliminate sumping (on a healthy engine).
Not necessarily, that depends on what configuration of the S&S pump is in the engine.
Old May 15, 2025 | 09:17 AM
MTBIG G's Avatar
MTBIG G
Said you removed the sump plug? Should be removing the crank position sensor and checking amount of oil, if any, comes out from there. You'd definitely notice power loss if you truly have an issue. With the mods you have, I wouldn't worry at all if it's running good.
Old May 15, 2025 | 10:36 AM
red shift's Avatar
red shift
It was the CPS that I removed, I'm swapping out the sump plug as a matter of routine (Feuling short #765.
There was a small but noticable loss of power afetr I beat on it for 20 miles or so chasing a KTM, thats how I detected the issue.
Old May 15, 2025 | 11:09 AM
red shift's Avatar
red shift
It's the correct unit for the bike year and type, I fitted it to replace the 10 lobe disaster that was stock on the early 2019 models.
Old May 16, 2025 | 09:02 AM
Max Headflow's Avatar
Max Headflow
Does it have the seal between the pump and case?
Old May 16, 2025 | 09:04 AM
red shift's Avatar
red shift
It does.
ntraindavefl's Avatar
ntraindavefl
20 oz is definitely a problem. Maybe recheck run out and the scavenge oring, if the leak down is solid
Old May 16, 2025 | 09:07 AM
Max Headflow
It does.
Replace it along with the case O ring.. Make sure the case O ring is Viton.
