stripped spark plug hole
Old Oct 10, 2008 | 04:25 PM
lowpasskid's Avatar
lowpasskid
Stage III
Thumbs up stripped spark plug hole
got a 06 ultra classic with a stripped plug hole.i got a 12mm helicoil but the plug
dosen't fit,helicoil is too big.does anyone here know if a 10mm is what i need?
i've searched HDF,the internet,with no luck.
thanks for any help.
Old Oct 11, 2008 | 09:04 AM
mopardave's Avatar
mopardave
do you mean that plug does not fit before you install the coil? If so, it will be smaller when installed.
Old Oct 12, 2008 | 01:44 PM
hogrider98's Avatar
hogrider98
sounds like a good excuse to install a big bore kit
Brian
Old Oct 12, 2008 | 08:11 PM
lowpasskid's Avatar
lowpasskid
Stage III
thanks for the reply mopardave.i haven't tapped the hole yet,was just checking the fit
of the new plug to the helicoil.it slides in and out instead of screwing in and the helicoil
seems to about 1/8" larger inside diameter than the plug's outside diameter.
once the helicoil is installed,will it compress that much?
thanks again for your help.
hogrider98,if it was mine i would do just that!
Old Oct 12, 2008 | 08:45 PM
mopardave's Avatar
mopardave
I got this off of heli-coils site. They can explain it way better than me.
In the free state they are greater in diameter than the tapped hole into which they are installed. In the assembly operation the torque applied to the tang reduces the diameter of the leading coil and permits it to enter the tapped thread. When the torque or rotation is stopped, the coils expand with a spring-like action anchoring the insert permanently in place against the tapped hole. No staking, locking, swaging, keying, nor interference fit is required to retain HELI-COIL Inserts, thereby eliminating stress concentration in the parent material. The HELI COIL Insert automatically adjusts itself, radially and axially, to any expansion or contraction of the parent material.
http://www.emhart.com/products/helicoil/standard.asp
P.S. Remember to make sure that the heli-coil thread at the opening (where you would start the install of the spark plug) is just below the surface so that it is less likely for you to accidently pull the heli-coil out. The heli-coil is essentially a precision spring and if it is too close to the surface, the end of the heli-coil could be pulled out due to lack of support of the tapped heli-coil thread. I hope I'm not confusing you here. Read their website for a better explanation...or call them. It's actually a lot easier than all this sounds. Good luck.
Old Oct 13, 2008 | 01:05 AM
dope_man_21's Avatar
dope_man_21
I have used heli-coils for a lot of things, but I do not believe I would try it on a sparkplug, head bolt, or any other use where the compression of an engine would or could effect it, but that is just me.
Old Oct 13, 2008 | 06:02 AM
sporty2003's Avatar
sporty2003
i have used them back when i raced. they work good you should be fine. but you know you got to pull the head so shaving's dont get in the motor.
Old Oct 13, 2008 | 06:04 PM
mopardave's Avatar
mopardave
There is no problem using heli-coils for spark plugs. they are actually far stronger than the aluminum threads that were tapped into the head.
You are better off pulling the head to do the job, but you don't have to. I have installed them on car engines by using a strong air vac while tapping the hole. The trick to it is to make sure that the exhaust valve is open so that the vac can actually suck air and debris up and out of the plug hole. When you are finished installing the heli-coil, if you are confident that a minimum of chips have fallen in, you can crank the engine over with the coil disconnected and the spark plug still removed. This will blow any possible remaining debris out of the cylinder.
I know this method works because I have done it, but the only way to be absolutely sure that shavings don't drop in is to pull the head for the work. It's up to you.
Good luck, Dave
Old Oct 13, 2008 | 06:05 PM
2008FLHP's Avatar
2008FLHP
YIKES!!!....be very careful
Old Oct 13, 2008 | 07:27 PM
mopardave's Avatar
mopardave
Hey, if you're scared, say you're scared! and pull the head! LOL
