97 EFI Evo Mods
Old Sep 6, 2010 | 11:04 AM
chadtil's Avatar
chadtil
2nd Gear
Default 97 EFI Evo Mods
I have a 97 Road King EFI That has a bad rod bearing and is need of a rebuild.Itseems like it would be a good time to stroke it,switch the cam etc.How much will the MM EFI handle? any suggestions? TYhanks for the help
Old Sep 6, 2010 | 07:30 PM
GAZRNR's Avatar
GAZRNR
There is a lot of info out there on what you can do. On my 98 RK EFI I went with a re-ring on the pistons, SE heads, Woods W6 cam, torrington bearing, SE lifters & push rods, Supertrapp Supermeg 2-1 exhaust with 18 disc & closed end cap and a Powercommander USB III. The bikeis much more fun to ride and he gas mileage improved from 42-43 stock to 48-49 now. Good luck with your build.
Old Sep 6, 2010 | 07:36 PM
schwangster's Avatar
schwangster
sounds like you both have great rides!
Post your questions in the EVO section.
There are some great minds and skilled mechanics in there.
See ya there.
Old Sep 7, 2010 | 05:41 AM
chadtil's Avatar
chadtil
2nd Gear
Thanks for the info,I will try the Evo post.
leohd
Jan 30, 2021 07:23 PM
bigwalt
Apr 27, 2014 05:39 PM
Littlejap1968
Apr 21, 2014 02:10 PM
J.H.
EVO
13
Feb 10, 2014 07:26 PM
PakMul
Exhaust System Topics
Sep 29, 2010 09:27 AM
