KB piston slap.
Old Apr 19, 2012 | 01:46 PM
Bodean46's Avatar
Bodean46
Default KB piston slap.
Anyone using KB pistons have an idea about how many miles before a rebuild? I used 10.5 to 1's and have piston slap that is noisy as all get out and i'm wondering how many miles i will get before having to tear down and rebuild with Wiesco 10.5's in my 97" BB?
Old Jun 1, 2012 | 01:47 PM
Bodean46's Avatar
Bodean46
Just replaced the SE pushrods with Fuelmoto's and what a difference. Most of the noise is now gone. The SE's had a slight bow to them so could never get valves set right and had quite a bit of noise. Now, it's almost quiet as stock top end.
Old Jul 14, 2012 | 09:10 PM
TwiZted Biker's Avatar
TwiZted Biker
KB pistons pistons are picky about break in with higher compression motor , skirts gall up fast and doesn't take much when they are fresh .
Old Aug 6, 2012 | 08:59 AM
n2ofaster's Avatar
n2ofaster
it has been my experiance that if the KB pistons are making noise, (piston slap) they were set up incorrectly. meaning the the clearances of the piston to wall is to large. These pistons like to be set up with tight clearances or they make noise. It is not usually the pistons problem but more of the boring job that was done. I have set these pistons up with less than .001" clearance and they do not slap and have great longevity. The weisco's will make the same noises if set up incorrectly. dsv
Old Aug 6, 2012 | 03:02 PM
Bodean46's Avatar
Bodean46
Had to install a set of Fuel Moto adjustable push rods. Sound ended up being the SE adjustable push rods bent on both cylinders.
Bologna
Engine Mechanical Topics
11
Mar 17, 2015 09:05 AM
Wingstop18
2014-2024 Touring Models
Dec 3, 2014 06:01 AM
Muganic
Exhaust System Topics
15
Nov 22, 2010 02:34 AM
customsoftail200
Apr 2, 2010 09:21 AM
scooter10572
Jun 7, 2008 02:46 PM
