Drilling Hole in muffler
Old Mar 5, 2013 | 04:00 PM
Harleyjunkie1997's Avatar
Harleyjunkie1997
3rd Gear
Default Drilling Hole in muffler
I have a 2006 Sporty and its all stock. I know that knocking out the baffles would affect the back pressure. Would drilling holes into the muffler affect the pressure?
Old Mar 5, 2013 | 09:58 PM
aquadave's Avatar
aquadave
that would be the worse thing to do. Drilling a hole will allow cold fresh air in the pipes causing pops and worse bent valves. pops are caused by hot unused fuel meeting with fresh air in the exhaust and igniting flowing backward and burning up exhaust valves and screwing up the flow of exhaust. believe it or not there is a formula for how long an exhaust should be for best performance at given RPM. but you have to go back to basic engine building to know that. Nobody ever goes back to basics
Old Mar 6, 2013 | 10:42 AM
Harleyjunkie1997
3rd Gear
Default Drilling holes in muffler
So what do you recommend I do? I'm tight on budget so buying a stage 1 kit and new muffler would be out of the question for awhile....what other possible ways are there to make the bike a little louder? and thank you for your reply!!!
Old Mar 6, 2013 | 10:47 AM
rubberfrog's Avatar
rubberfrog
It only works if you live in a trailer.
Old Mar 6, 2013 | 11:16 AM
Dangermouse's Avatar
Dangermouse
What about torque cones, can he pull the baffles and use them? Not sure what they do.
Old Mar 6, 2013 | 11:39 AM
Dangermouse
Use the search feature and search torque cones. There are some interesting threads
Old Mar 6, 2013 | 11:47 AM
Harleyjunkie1997
3rd Gear
Sweet, I will search that right now. What kind of scoot you got?
Old Mar 6, 2013 | 11:49 AM
Dangermouse
I have a 1999 Electra and my old lady has a wideglide
Old Mar 6, 2013 | 11:50 AM
65van's Avatar
65van
Stage III
I drilled mine out 3 years ago, 1" drill, one of the best things I'd done, added torque cones and adjusted air mixture. Runs like a scalded Hog...sure sounds better..
Old Mar 6, 2013 | 11:52 AM
Dangermouse
You can find torque cones. On. Ebay relatively cheap
