Screamin' Eagle 103 ci Street Performance Stage 4 Kit
Old Jun 2, 2014 | 10:06 AM
akhuntr's Avatar
akhuntr
2nd Gear
Default Same issue
Originally Posted by helenmcr1@gmail.com
I just had the Stage 4 kit installed on my 13 Ultra and I am noticing more top end noise than before. Has anyone else had this happen? I have done 4 smart tune runs so far and the bike runs great, I just was wondering if the increased noise was something I should be worried about.
I also have 13 Ultra and had the Stag 4 kit installed along with a 2-1-2 ceramic coated header and Vance & Hines Monster Ovals. The engine diffinitely has more noise coming from the top end. I took it back and the tech tore into the top end and could not find anything wrong. I was told it was normal. I havent had it dyno'd yet so not sure what kind of numbers I'm getting yet.
Old Jun 3, 2014 | 04:35 AM
helenmcr1@gmail.com's Avatar
helenmcr1@gmail.com
My dealer called their tech support and was told it was because of the heavier valve springs. What you are hearing is the valves closing because of the heavier springs. So I guess it is normal.
Old Jul 15, 2015 | 04:59 AM
akhuntr's Avatar
akhuntr
2nd Gear
I picked the bike up yesterday. The tech said he had to play with the timing on it. Whatever he did the noise is gone. However, the bike doesn't seem to be as strong as it was before. Prior to having the pro tuner and Dyno work done there was a serious valve spring noise. The tech told me it would go away with the pro tuner and Dyno tuning. It did...but since he worked on it, the valve spring noise is back. I don't mind the noise, it's the lose of power since I got back that's bothering me now.
snccpl
Milwaukee Eight (M8)
Apr 27, 2017 08:25 AM
strato chief
Dec 15, 2015 10:30 AM
bald1der
Aug 19, 2015 05:29 AM
tazman509
Jul 30, 2012 06:19 AM
HarlyFan
Sep 30, 2007 11:51 PM
