Chev 350 lifters
Old May 25, 2014 | 03:22 PM
Ron C's Avatar
Ron C
Default Chev 350 lifters
Hi
I hear you can use a 350 chev lifter in a TC 96 anyone done this?
If so what lifters will be the best to use?
Thanks
Old May 25, 2014 | 04:09 PM
lt1-xjs's Avatar
lt1-xjs
Originally Posted by Ron C
Hi
Thanks
I installed the Comp Cams 850-1 and have almost 4k on them. Changed oil yesterday and all looks good.
Old May 25, 2014 | 04:38 PM
Ron C's Avatar
Ron C
Hi
Thanks for the info.
Just wondering if anyone else used them or another brand.
Old May 25, 2014 | 06:02 PM
dawg's Avatar
dawg
I run Gaterman GP 1023's. Nice and quiet
Old May 26, 2014 | 12:46 AM
Chaddilac's Avatar
Chaddilac
From my understanding the lifters are good for 20-30k so me and a buddy went in halfsies on a full set (16) of the comp cams 875 limited travel lifters, figuring we would use them anyways. he is running them set 12 flats deep with s&s adjustables on woods 777's and they are quieter than a mouse in slippers
Old May 26, 2014 | 09:19 PM
Ron C's Avatar
Ron C
Hi
Im going to use SE 255 cams in my bike.
So you think one of those lifters will be ok with that cam?
Old May 30, 2014 | 02:01 PM
Chaddilac's Avatar
Chaddilac
I just finished using the comp limited travels in another build (107 hillside) with 585 cams ans the were so quiet I was laughing but your results may vary the ones with .200 of travel are the 850 and the .110 travel are the 875 for 200$ for 4 sets of them I'm very please with how they run and sound in both bikes
Old May 30, 2014 | 06:31 PM
mirrmu's Avatar
mirrmu
Hi
hi,
i would inspect your lifters first RonC unless you got mega miles on them, there is a spec in the manual for checking lifter and bore, recently changed cam and I re-used the stock ones as wear check all good
thanks
mirrmu
Old May 31, 2014 | 03:56 PM
Ron C's Avatar
Ron C
Default Re lifters
Well I don`t want to use the ones in the bike.
Since im installing new cams and pushrods id like to replace the lifters as well.
Old May 31, 2014 | 06:30 PM
mirrmu's Avatar
mirrmu
Hi,
Go for it
Thanks
Mirrmu
