Loud noise when starting
Old Jun 19, 2014 | 05:18 AM
hooter23's Avatar
hooter23
Default Loud noise when starting
Once in a while when starting bike the starter sort of drags and then loud clank and then starts. What could it be and curious cost of replacing
Old Jun 19, 2014 | 07:39 AM
magnum629c's Avatar
magnum629c
Mine does it once in a while. I allways thought it was just when the starter teeth match the ring gear and they just hit.. When it does it I give it a second and fires up normal this happens cold.. And hot sometimes mine will start slow and the starter will even stop that's just from my bike having to much compression... But if ur battery is weak it will do that. How Olds the battery?
Old Jun 22, 2014 | 01:14 PM
wannabebagger's Avatar
wannabebagger
Stage I
mine did same thing was the compensater spring look at se replacement
Bubba Zanetti
Jul 13, 2019 02:58 PM
nicmartim
Aug 7, 2016 06:28 AM
customsoftail200
Jan 11, 2013 07:17 PM
vascik883
Dec 13, 2009 07:57 AM
lbarbish
Sep 22, 2007 01:36 PM
