What is this?
Old Jun 19, 2014 | 09:01 AM
billversity's Avatar
billversity
1st Gear
Default What is this?
Can anyone tell me what this thing is that is hanging underneath my 92 FLHS? It does not appear in my manual, does not appear anywhere that I can find in the online microfiche drawings. It appears to be connected via the hose on top to a 90 deg. fitting coming out of the side of the crankcase. The hose coming out of the bottom of this thing may or may not have been the source for a small (maybe 2 in. diameter) spot of moisture on my garage floor.
Could it in any way be related to the fact that my machine was running fine on Sunday, but on Tuesday it was rough starting and the engine ran very roughly?What is this?-flhs-mystery-object-1a.jpgClick image for larger version
Name:	FLHS Mystery Object 1A.jpg
Old Jun 19, 2014 | 09:17 AM
nhrider1's Avatar
nhrider1
Could it in any way be related to the fact that my machine was running fine on Sunday, but on Tuesday it was rough starting and the engine ran very roughly?Attachment 385161Attachment 385161
Looks like someone may have added a crankcase breather valve. It didn't come from the factory like that.
Old Jun 19, 2014 | 01:53 PM
prodrag1320's Avatar
prodrag1320
it looks like a "pre-filter",their used on drag bikes or customs as a oil filter on the feed line.putting it on the breather wont hurt or help anything.if it is a one way valve,like a PCV valve (some guys will put them on the breather line) it wont hurt anything either
Old Jun 19, 2014 | 02:30 PM
hvacgaspiping's Avatar
hvacgaspiping
, and it looks like a filter on the outside surface which is plugged up and needs to be changed.
Old Jun 19, 2014 | 03:01 PM
prodrag1320
yes,if it is plugged on the end,it needs to be unplugged (looks like its just a piece of hose on the end,but if it is a plug,unplug it)
Old Jun 19, 2014 | 03:08 PM
hvacgaspiping
I have a filter similar to that on my sig bike without a hose on the end of it, but the filter has an inlet ONLY. So, I`m going to assume that it`s crankcase breather, and that the filter keeps out dirt from the road without oil leaking from it.
Old Jun 19, 2014 | 06:27 PM
qtrracer's Avatar
qtrracer
Maybe a Hayden Crank Vent?
Old Jun 20, 2014 | 05:22 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
I'd suspect that is it, or a rendition of that.
Glorified nothingness.
Scott
FLshovelhead
Jan 18, 2021 07:28 PM
1982DSB
Dyna Parts
Oct 14, 2016 09:03 PM
californiafatbob2013
Dec 30, 2014 01:24 PM
highbarst
EVO
41
Apr 1, 2014 08:32 PM
highbarst
EVO
Dec 6, 2013 09:59 PM
