cold start hell help!!!!!
Old Aug 12, 2014 | 11:06 AM
02 heritage's Avatar
02 heritage
6th Gear
Default cold start hell help!!!!!
On the first start of the day my 02 heritage sputters and backfires thru the exhaust. I put new plugs in and new air filter, also had it checked for intake leaks there were none. It only does this for a short time then is fine all dsy even if it sits for 3-4 hours. Please help me figure this out
Old Aug 12, 2014 | 04:40 PM
JimGnitecki's Avatar
JimGnitecki
After my HD dealer installed the Stage 4 race kit on my 2014 Breakout, I too had problems right after each FIRST (only) cold start of the day.
The bike would start right away, but the rpm would "hunt" for a couple of minutes, and the bike had to be nursed to keep it from stalling.
Then an expert tuner, Mike Lozano, who happens to have his shop near where I live, did his tune on the bike. TOTALLY resolved the problem.
In looking at the Power Vision software afterwards, I could see he changed the percent enrichment versus ambient outdoor temperature, for almost all the cells in that table.
Now, instant start, and instant stable rpm and instant drivability.
Get a GOOD tuner to tune that problem out.
Edit: Sorry, I did not ask if your bike is fuel injected or not - I assumed it was. If not, disregard what I said.
Jim G
Old Aug 12, 2014 | 04:58 PM
qtrracer's Avatar
qtrracer
First of all did this just occur on it's own or did it start happening after a part was added or ? Second of all is this bike carburated or fuel injected? Thirdly what, if any, modifications from stock have been performed?
Old Aug 13, 2014 | 11:19 AM
02 heritage
6th Gear
New air filter and plugs put in. No other changes. Before the filter and plugs it had a slight hiccup at cold temps in am or night. That stopped now I have this. It is carbureted
Old Aug 13, 2014 | 11:41 AM
lt1-xjs's Avatar
lt1-xjs
Are you using the choke/enricher during this time? Sounds like it's ok after it warms up.
Old Aug 16, 2014 | 12:59 PM
02 heritage
6th Gear
Yes it is good when warmed up . I ran seafoam thru it and tried shutting petcock off .it started and ran great right away this morning. Dont know why just happy about it!!#
Old Aug 17, 2014 | 10:15 AM
deuce_streetbob's Avatar
deuce_streetbob
Jim G
can you tell me how much he changed the % enrichment? like where it started and where it was finally set? i'm having a similar issue where it starts fine, then at as it approaches 100 degrees it will start having sputtering issues and i have to be on the throttle a little to keep it going. after a few moments, it will idle fine, but it seems to be in certain temp ranges.
Old Aug 17, 2014 | 01:18 PM
JimGnitecki
I'm sorry but since I lost my job, I no longer have access to a Windows computer so cannot fire up the PV software to check the tables ( my wife and I use Mac machines).
Jim G
Old Sep 13, 2014 | 02:29 PM
02 heritage
6th Gear
Turns out it was ignition module good as new now woohoo
rcornelius
Apr 25, 2017 10:26 AM
02 heritage
Aug 11, 2014 08:00 PM
jeffwest5599
Exhaust System Topics
Aug 13, 2010 12:39 PM
harley_nova
Feb 15, 2009 02:20 PM
geedub
Dec 3, 2007 05:52 PM
