Lifter installation ??????????????????
Old Aug 20, 2014 | 08:07 PM
californiafatbob2013's Avatar
Default Lifter installation ??????????????????
Hey guy's I have a question on installing lifter in a 2013 twin cam 103ci.
I am going to be installing cam's, lifters, and new push rods.........
Here is my question, once the cam chest, oil pump, and cam's are removed can the new lifter's be installed from the underside with out removing the tappet cover's ?
I realize they need to line up with the alignment pin, just wondering if I could save some time by installing from the underside before cam's go back in ?
Thanks for your replies ............
Live Free = Ride Free............
Old Aug 21, 2014 | 10:28 AM
northeastconfederate's Avatar
No, they cannot. I've tried to slide them through like that and they won't do it.
Old Aug 21, 2014 | 10:38 AM
r0de_runr's Avatar
r0de_runr
do not take out the 4 screws holding the oil pump to the cam plate.
Do Not.
It is not necessary to remove the oil pump from the cam plate to swap cams.
Old Aug 21, 2014 | 11:16 AM
djl's Avatar
djl
Originally Posted by californiafatbob
I realize they need to line up with the alignment pin.
Actually, the pin is the "anti-rotational" pin and therein lies the difficulty. Kudos for taking on the project as a DIY endeavor but you are talking about saving 15-20 minutes and the cost of gaskets. Not much compared to total man hours and cost for the project? Smart to ask though; asking definitely save you some time.
Old Aug 21, 2014 | 01:36 PM
Default Lifter Install Question ?????????
Thanks to all that have posted up !!!!!!!!!!!!!!!
Old Aug 23, 2014 | 10:58 PM
Strahley's Avatar
Strahley
Not gonna happen. When you put the new ones in, make sure they are seated correctly to where they are not able to turn/rotate (those anti-rotational pins are very important). I checked mine a few times at different heights (by rotating the cams...the lifters will go up and down as the cam lobes rotate) before I was satisfied enough to bolt the covers back on
Some people say to soak the lifters before installing them, some say don't. I didn't soak mine
Old Aug 24, 2014 | 12:12 AM
Default Lifter Install...............
Thanks for the post and the info about soaking..........
So when you started the engine did you get any lifter noise until they pumped up ?????
Thanks again..........
Live Free = Ride Free.............
Old Aug 24, 2014 | 10:24 AM
djl's Avatar
djl
Yes, the valve train will rattle like a thrashing machine for a minute or so while the lifters pump up. I don't soak mine either.
Old Aug 24, 2014 | 04:36 PM
Strahley's Avatar
Strahley
I can't start mine yet, still waiting on the cylinders and heads to make their way back to me. Hopefully here within the next few weeks they will get here
But I fully expect them to make some extra noise at first. Seems that's the norm for new lifters
Mberlin74
Engine Mechanical Topics
16
May 1, 2016 07:18 PM
Mattster
Nov 29, 2015 08:45 AM
Madcop
Aug 14, 2014 09:52 PM
06Cummins
Jul 23, 2014 02:00 PM
Strobe
Jul 20, 2012 12:06 AM
