New cams
Old Sep 13, 2014 | 03:32 PM
outlaw0013's Avatar
outlaw0013
Default New cams
Just had a local indy install some new andrews 26g cams in my 06 SG. He said the gears are very tight. Sounds like I'm running a turbo on it now. Whines big time. Going to have him install some smaller gears to eliminate the noise from the gears. It's also making a rattling sound when idling. Was wondering if anyone else has has this happen. The sound seems to be coming from the compensator sprocket area but I'm thinking it's actually from the cams traveling through. Never had the noise before the install. Cams only have 490 lift so I don't think lifters are coming up and not following the lobes properly. Used the stock lifters. Only 19,000 miles on bike. Any ideas would be helpful before I run it back to him.
Old Sep 13, 2014 | 07:32 PM
C.J's Avatar
C.J
What was the spec on the crank run out before the install? Too much run out can be a problem.
Old Sep 13, 2014 | 10:25 PM
magnum629c's Avatar
magnum629c
Sounds like u have lots of runout
Old Sep 14, 2014 | 07:25 AM
prodrag1320's Avatar
prodrag1320
all run out & gear lash should have been checked during install.we do ALOT of gear drive installs and don't have these problems because everythings checked.
Old Sep 14, 2014 | 10:20 AM
outlaw0013's Avatar
outlaw0013
Don't know what he did. Wasn't there when I picked the bike up. They guy I spoke to said he was told gears were tight. I'll get back once I get to talk to him. Went by the shop yesterday but they were closed for an event.
Old Sep 15, 2014 | 05:29 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Should be plenty quiet with that cam.
Loading the lifter to the proper specification with an adj. pushrod is how we accomplish that here.
Scott
mrhammer2u
Mar 3, 2017 10:04 AM
Plaidfinger
Aug 4, 2012 07:50 AM
Taterdog
Jan 20, 2008 04:30 PM
Quickie
Exhaust System Topics
Sep 5, 2007 04:37 PM
grumpy irish again
May 17, 2007 09:51 PM
