Air Fuel Ratio Question
So while you have chosen a convenient location for your sensor, it seems bound to be giving you false readings. Not all the exhaust from the rear cylinder is passing the sensor, for example and as Greg points out, the gases in the exhaust continue to burn as they pass down the pipes.
I suspect you will need to make a variety of small adjustments, but using your meter readings for interest, rather than as a reliable guide to things being just so.
I will keep changing the map until that is gone. The bike is running great, I just need to take a rode trip to see how it runs on the interstate. My gas mileage has gone from 34 mpg to 43 since I got the bike last year, from me adjusting the map.
I got a email from power commander
Thank you for your inquiry and support of Dynojet products, it sounds as though you have your O2 sensor too far back in the exhaust and you are getting some extra air past the sensor, either because of an exhaust leak, or fresh air from the end of the tail pipe (Reversion) which is skewing your readings, the bike is not and would not idle at 17.5 true AFR, we would recommend checking the system for exhaust leaks or possibly relocating the O2 sensor closer to the heads for a cleaner sample, if the rest of the AFR under load looks good and the bike is running ok, you may just want to add some fuel at idle or have the bike dyno tuned to optimize performance, thank you, ride safe.
When I get the new exhaust it will have the bungs closer to the head.
Thanks to all for all the information.....
When you add timing you also will find it will slightly lean that area on the map and if you are doing a Power Commander format, a -5 in the 0 throttle area will kill any popping thru the exhaust on decal, sometimes it takes a -10 to work but you are adding fuel to cool the exhaust down. Good Luck, you have some sleepless nights ahead of you
