bike not turning over? jumping worked....
Old Dec 10, 2014 | 06:01 PM
  #31
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
texashillcountry, the process I posted will check the ground circuit for the relay.
If there is a voltage reading at terminal 85 of the relay it indicates a bad ground. A good ground will read zero voltage.
I didn't say you were wrong.
I said I think a bad ground was the source of both of his problems.
Old Dec 10, 2014 | 06:26 PM
  #32
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I didn`t mean it that way, I was just pointing it out because my post is pretty long winded....
I`m suspecting that if the OP checks terminal 85 with his voltmeter, he will find that the ground is bad, or that black wire that he was referring to is the ground wire, and it is not connected to terminal 85...
Old Dec 12, 2014 | 02:24 PM
  #33
800screws's Avatar
800screws
ok! starter working! thanks...............bad ground
now the signals...this is real weird so I hope its not hard to understand...
one side works fine, the other side signals do not work but the dash bulb lights really dim im getting 6 volts on the marker wire...
now if I remove the dash bulb from the side that's not working, the signal will light up but does not flash, just stays lit........
but if I take the dash bulb from the side that works and plug it into the other side dash socket then that side works!
and if I try swapping bulbs...that one bulb in particular works, and every other one doesn't........
also if I press both signal buttons then everything works in unison on both sides!
I am super lost!
Old Dec 12, 2014 | 02:33 PM
  #34
Dan89FLSTC's Avatar
Dan89FLSTC
What did you connect the voltmeter to when you got the 6 volt reading, were you touching the probe to the bulb socket, was the bulb removed?
My first thought is excessive resistance somewhere in the circuit.
Remove the tanks, and get to the three electrical connectors near the steering head. Unplug them and clean the terminals, look for corrosion. Make sure none of the terminals have backed out of the connectors.
Clean the connectors at the signal flasher unit.
Old Dec 12, 2014 | 02:51 PM
  #35
800screws's Avatar
800screws
1990 softail custom
Old Dec 12, 2014 | 02:59 PM
  #36
texashillcountry
Dirt don't hurt
I am super lost!
As I said before I think your problem is a bad ground.
Old Dec 12, 2014 | 03:02 PM
  #37
800screws's Avatar
800screws
indicator bulbs are the ones im talking about as the dash bulbs...............
I have the whole bike torn apart I cant find anything.....
Old Dec 12, 2014 | 03:37 PM
  #38
Dan89FLSTC's Avatar
Dan89FLSTC
Take a deep breath, relax...We will get you to the bottom of this..
Are the fuel tanks removed?
Do you see the big electrical connectors?
Old Dec 12, 2014 | 03:52 PM
  #39
800screws's Avatar
800screws
oh yeah everything is off...tanks...rear wheel...all wiring is exposed.
Old Dec 12, 2014 | 03:57 PM
  #40
Dan89FLSTC's Avatar
Dan89FLSTC
Do you have all good bulbs in the turn signal sockets (don`t worry about the indicators, yet)?
Got your voltmeter handy?
