head volume
Old Feb 16, 2015 | 08:58 PM
graultytc88's Avatar
graultytc88
Originally Posted by D_gyver
stock is suppose to be 83cc but it can be anywhere from 81cc to 85cc. if yours are 74 they have been cut thats the volume that most hot rod builders shoot for. with 74cc heads .030 head gasket wiseco 10:1 pistons .003 in the hole and a wood w-9 cam will give you 11:1 static compression and 9.67:1 corrected that's as high as you can go on pump gas.
with flat top pistons and ev51 cam your static would be 9.3:1 and corrected is 8.4:1
Glad you brought that up, because I'm not clear, when Andrews recommends 9 or better comp. for this cam, are they referring to static or corrected? I'm assuming static; corrected seems to be referred to less.
I'm not looking to race, just have some over stock so I don't get lost behind the newer bikes.
I hade an evo with the headquarters system 85 setup and that ran well, this Andrews cam seems a bit bigger, but not a huge amount.
Old Feb 16, 2015 | 09:17 PM
D_gyver's Avatar
D_gyver
the magic number is 9.6:1 corrected if you put 10:1 wiseco in it and a .045 head gasket you will be at 9.6:1 corrected the bike will be a beast.
right now your motor has to big of a cam its probably a little soft on the bottom end. go with a ev27 or wood w6
or more compression.
Old Feb 16, 2015 | 09:23 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Isn't the 45 thousanths head gasket the stock one?
Old Feb 16, 2015 | 09:25 PM
graultytc88
Thanks for the advise, I'll likely go with more compression, doesn't make sense to build down while I have it half apart.
Old Feb 16, 2015 | 09:34 PM
D_gyver's Avatar
D_gyver
yes stock
Old Feb 16, 2015 | 09:47 PM
D_gyver's Avatar
D_gyver
make sure and check your deck height before you buy head gaskets so you can get the correct compression ratio you don't want to go over 9.6 corrected or you will have detonation problems and never run anything lower than 92 octane.
if you want to be safe you could buy james .060 head gaskets with the 10:1 pistons and that cam you would still be at 9.3:1 corrected.
Old Feb 16, 2015 | 10:07 PM
graultytc88
I'm measuring .009 below so I don't think the .040 is any problem, and maybe a 9.5:1 piston might be a safer choice. Granted, it's not the motors "full potential" but will probably suit me. It's hard to find even 91 octane around here, and I don't want to have to carry additive with me everywhere I go.
I have a friend with a stroked shovel that's running 10:1 with a big cam and he always has to add. Oh, and rebuild often too!
Old Feb 16, 2015 | 10:43 PM
D_gyver's Avatar
D_gyver
yes a 9.5 would be better but wiseco doesn't have one and they are the only pistons I will buy. they are a superior product
Old Feb 17, 2015 | 09:31 AM
LowriderHarold's Avatar
LowriderHarold
the magic number is 9.6:1 corrected .
Hey D,
One question. All info that I have found, says to keep the corrected compression around 8.9:1 to 9.1:1 for a good streetable motor. I'm at a measly 8.56:1 right now, and have had a couple hard starts, this past summer & harder starts , this winter, with compression bumped to what it is now. Added new battery, new AllBalls starter, BDL 84/10 ring gear kit, new Terry battery cables. Not a real problem in warm weather, but is when temps get below 55. Went to lighter weight oil, & helped some. So I pulled the heads, couple of weeks ago, & put Compression release's in them to help, & had my indy cc the heads to give me a 9.0:1 corrected. My question to you is , where did the magic number of 9.6:1 come from? Not saying thats wrong, just trying to learn. Got a link to a article?
Sorry to the OP for the hijack.
Ride Safe,
Harold
Old Feb 17, 2015 | 10:14 AM
graultytc88
Originally Posted by LowriderHarold
Hey D,
Ride Safe,
Harold
No problem! Ask away, only way to gain info.
