head volume
Old Mar 8, 2015 | 10:50 AM
  #81
D_gyver's Avatar
D_gyver
Originally Posted by Dr.Hess
That's not going to be VGA. That's going to be Serial, and if I had to GUESS, I would GUESS RS232. Count the pins. I've seen those USB cables for tuning the Dynatec, etc. ignitions. I'm going to GUESS that they are a USB to RS232 converter, which you can buy for a few dollars from various outlets.
you are correct the dyna ignition uses a old school serial connection. off the top of my head I think its pin 3 data TXD goes to the tach wire pin 2 RXD goes to the voes wire and pin 5 is ground. most new computers don't use serial connections anymore that's why you need a usb to serial converter
Old Mar 8, 2015 | 10:55 AM
  #82
98hotrodfatboy's Avatar
98hotrodfatboy
Default My apologies Graulty....
The thread was going a different direction, and yea you still have good life in those cylinder walls.
Old Mar 8, 2015 | 11:03 AM
  #83
graultytc88's Avatar
graultytc88
I know... just felt like being a d**k because I can't get into the minutia of electronic tuning. I have the power vision for my tc96 and it just makes my head hurt. This is why I'm going back to the evo; to simplify.
Old Mar 8, 2015 | 11:04 AM
  #84
D_gyver's Avatar
D_gyver
Real time AFR monitoring is nice, I hear they work well. D, do you have a Dynatek ignition programming kit? If so I see that it has a VGA connector, can you use a vga to usb connector to a laptop and will it still work? I'm thinking of getting one to customize the preloaded curves from Dynatek...
after hours on the dyno trying to get the AFR right and then taking it out for a ride gets you close but real time monitoring is way better and when I get it dialed in ill put plugs in the bungs on my exhaust and remove it and put it on the shelf for the next build
Old Mar 8, 2015 | 11:13 AM
  #85
98hotrodfatboy
Default Cool....
Good decision there........gotta love them Evo's......
Old Mar 8, 2015 | 11:30 AM
  #86
D_gyver's Avatar
D_gyver
the dyna ignition is way easier than a power vision
when Im riding if I notice any ping or spark knock I look at my tach when I get home I plug it in and remove a little advance from the curve at that rpm
it took a few weeks to dial it in but now im getting max advance without detonation.
Old Mar 8, 2015 | 12:31 PM
  #87
98hotrodfatboy
Default peak performance...
can't wait to start......
Old Mar 8, 2015 | 06:42 PM
  #88
1997bagger's Avatar
1997bagger
Going to start a new thread so this one can stay simple.
grieker
Oct 23, 2014 08:53 AM
prodrag1320
Jan 19, 2010 04:26 PM
midnight2005
Exhaust System Topics
Oct 19, 2009 07:00 PM
grattray
May 6, 2007 03:15 AM
