New Battery. ....
Old Feb 23, 2015 | 07:35 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Default New Battery. ....
Brand new battery in October, 320 cca. I was transporting it in the back of my jeep yesterday (bringing it home to charge) and just my luck it falls over and shorts out on the metal strip off the snow shovel for about 7 seconds and catches on fire. Scared the crap out of me. Fortunately the case did not burn through and still reads 12.85 volts. What do you think, is it trust worthy?
Old Feb 23, 2015 | 07:40 AM
WP50's Avatar
WP50
Ya might see if it will load test. Would suprise me if you can get someone to do it.
Id bet your gonna be told it's toast
That's gotta be bad on the pocket book also
WP
Old Feb 23, 2015 | 08:25 AM
nhrider1's Avatar
nhrider1
If the battery still reads 12.85V it may be OK...but I wouldn't use it with those damaged terminals.
You can see the kind of heat it generated...basically a dead short (arc welder)...so Its likely there may be some internal damage as well.
Old Feb 23, 2015 | 08:36 AM
98hotrodfatboy
Default safety first.
Yea, it's just a crapy way to learn a lesson. A $150 lesson.....should have just left it in the bike.... off to the store I guess....thanx
Old Feb 23, 2015 | 11:59 AM
Uncle G.'s Avatar
Uncle G.
I've dropped a metal flashlight across the terminals of a car battery once. Won't do that again.
When I carry a motorcycle battery in the car, I put it in a plastic bucket. Just in case.
Old Feb 23, 2015 | 02:37 PM
Ruggs59's Avatar
Ruggs59
Try this place Batterymart.
usually free shipping
http://www.batterymart.com/c-harley-...1997-1999.html
Old Feb 23, 2015 | 04:39 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Luckily the battery didn`t explode...
Now ya gotta go get a new snow shovel too since you probably threw the one you had out into the woods....
Old Feb 23, 2015 | 04:54 PM
big cahuna's Avatar
big cahuna
If there's any way to secure the cables on it , I would try to use it. You've got nothing to loose at this point. I'm pretty sure they won't warrenty it with that damage.,,,
Old Feb 23, 2015 | 05:19 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Seriously?
He has a lot to lose...That battery can never be trusted to be safe.
Old Feb 23, 2015 | 05:27 PM
Ruggs59's Avatar
Ruggs59
I had one blow up on me in a 74 FL shovel. The positive is real close to the rear rocker box. It was a new battery and the ground is realy tight to get to when the battery is sitting where its supposed to be on the tray. so put the ground on and slid it in, then putting the chrome covers on it shifted and BANG! Just as loud as a high powered rifle going off. I was lucky i didnt get the acid in my face. It runied the chrome exhaust. I did have a water hose near by. and douched the whole bike. I have a lot more respect for batterys now...
