Dragging clutch
Old Mar 15, 2015 | 11:03 AM
  #31
glidein wide's Avatar
glidein wide
I don't order it,local shop stocks it.
Old Mar 15, 2015 | 11:20 AM
  #32
glidein wide
Originally Posted by texashillcountry
I didn't think you were making it up I had just never heard of it before.
FWIW I only put fluids in my bike that I can get at any auto parts store.
That way if I'm on the road and need more it is easily accessible.
The double pic was not intentional, not much of a computer head.
Old Mar 17, 2015 | 04:17 PM
  #33
Ducky 149's Avatar
Ducky 149
Had the clutch drag on my 97FLHTC on a trip. Got home and took it apart and found shock absorbing clutch plate had fallen apart. Consulted with a friend that was a HD dealer tech and he said happens all the time. Replaced clutch with a set of plates from J&P that said extra plate kit. Was all better after that. Good luck!!
Old Mar 17, 2015 | 05:21 PM
  #34
Big Dave's Avatar
Big Dave
Just curious as to what the extra plate kit would do over standered ?
Thanks
Dave
Old Mar 17, 2015 | 05:27 PM
  #35
Ducky 149's Avatar
Ducky 149
The shock absorbing plate is a bit thicker than a standard friction or steel. It takes up the extra room in the clutch pack that removing the absorber plate generates.
The extra plate makes the stack height correct for the clutch basket.
When mine came apart there were little brass screws or rivets that came loose and cocked up the clutch.
If you go to J&P web site and look up stock HD clutch parts I believe it is shown.
Old Mar 18, 2015 | 06:16 AM
  #36
flhchaz's Avatar
flhchaz
Same thing happened to me. I went this the HD Screamin Eagle heavy duty clutch. Same one that is in the Police bikes. No more spring plate, but a much heavier lever pull. big improvement over the stock set up with the spring plate.
Old Mar 18, 2015 | 01:59 PM
  #37
shimaze's Avatar
shimaze
Exclamation Me too!
I have adjusted my clutch three times in the last three days! When I pulled into the garage, the clutch was pulling so hard, it stalled when I came to a complete stop. Instead of fooling with it, I will just go ahead and replace the clutch. Will Barnett P/N 307-30-20011 work for my 1990 Springer? What is the difference between Kevlar & carbon fiber, other than a few dollars in price?
Thanks, Shimaze
http://www.barnettclutches.com/
BTW> I am a safety phobia/OCD person. I can see that not being able to disengage the clutch is an accident waiting to happen, especially if you can't shift into neutral. To stop the bike, I guess you would have to use the kill switch. The engine would still turn and slow the bike down. But at some point, near complete stop, I would suspect that the tire would lock up? This theory would be greatly exacerbated if it were raining and/or turning? Any would tried killing the motor and not pulling in the clutch lever?
Old Mar 18, 2015 | 03:42 PM
  #38
glidein wide
Kinda like when the clutch cable snaps while you're riding, dreading that day seeing I have no kill switch. Guess I'll hit the ignition switch.
Old Apr 4, 2015 | 12:37 AM
  #39
shimaze's Avatar
shimaze
Exclamation Full speed ahead, ...no clutch needed!
Originally Posted by Freebirdsride1
On the 90yr. Evo flhtcu 5 speed clutch adjustment at room temp 80% (If clutch discs & plates are installed in hub properly to specs) #1 the clutch lever cable adjustment is turned to it's losses point. #2 remove the clutch inspection plate on the primary housing. #3 loosen the jam nut on the adjuster screw and back the screw out for play on the clutch push rod. #4 grab the clutch cable and pull then push to seat or settle the ***** the clutch cam in side the trans housing. #5 make sure the cable is loose before you go to the clutch hub to adjust the push rod screw. Turn the push-rod screw inward to remove the slack in the outer hub-plate and the clutch-cam #6 Back out the screw tell you see the plate move to Zero lash. Turn the allen screw out a half turn if cold or three quarter of a turn if warm, tighten lock nut. #7 go to the cable adjuster and remove are the slack in the cable to the lever, pull on the lever and look at the clutch plate to see if it is working. Pop the lever out two or three time and see if the play is the same if so good now adjust the lever to one/eighth inch or to your liking. Install inspection plate on primary side and go for a ride.
Will these detailed instructions work on my 1990 Softail Springer? I just bought this motorcycle a couple of months ago. I have no idea what the previous owner did. I have been having a lot of problems with the clutch not releasing. When I am stopped at a traffic light, it wants to pull. I have to hold it back with the brake. If I release the brake, the motorcycle will take off fast enough that I can ride it (while holding down the clutch lever) I have adjusted the in-cable clutch adjustment three times in three days. Heat seems to make it much worse, but I don't know if letting it cool down will ease up the clutch?
I am in the process of changing all the fluids. Do I need to take the right transmission cover off? I have a gasket for it and the trans is empty (waiting to put the trans fliud in it). The trans was low on fluid, but not completely empty. I would take the cover off to look at it, but I am not sure what can be done with the ball & ramp and other associated parts. The primary is empty and I plan on refilling with ATF. The primary was at the normal level it was supposed to be. With the way the clutch was pulling, I expected it to be dry. The fluid looked pretty thick.
Any suggestions are greatly appreciated. I am a good car mechanic, but this is the first Harley I have ever worked on.
Old Apr 4, 2015 | 03:45 AM
  #40
grbrown's Avatar
grbrown
Wink
Hi Shimaze, yes those instructions will work for your bike. Having owned my 1990 bike from new I can assure you that clutch adjustment is critical, to stop that creeping when stationary. Another tip is to get into the habit of snicking into neutral while rolling, just before you stop.
I strongly recommend you get yourself a factory service manual asap, which will answer all your questions on servicing your bike. As an established mechanic I reckon you will appreciate the way it is compiled and the info it provides.
