Throttle Cable, HELP
Old Mar 13, 2015 | 09:41 AM
lowriderjim's Avatar
lowriderjim
Default Throttle Cable, HELP
I'm working on a 94 Softail Springer. I have a service manual but this bike has a S&S Shorty carb and was told the apes are 16" so the lengths and connections at the carb end are different from stock.
I was hoping that I could pull the old cable inner steel cable to replace and not have to replace the chrome braided sheath. Does this make sense?
Any tips from your experiences would be appreciated.
Old Mar 13, 2015 | 09:46 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Unless it's some type of add on cover, I doubt it. New cables on conversions are best. Messing with old throttle cables is almost like modifying old brake lines.. Sort of a compromise on safety to you and others.
Old Mar 13, 2015 | 10:02 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I just put some 16"s on mine.
'95 Heritage. It also has a S&S E.
I used +4" cables from Barnett and they fit fine.
Your stock cables won't work even if you replace (which I wouldn't try) the inner steel cable.
You have to remember one end of the outer has to fit into the bracket on the carb and the other screws into your switch housing.
Old Mar 14, 2015 | 06:51 PM
lowriderjim
Thanks for the info guys. I have the broken cable removed and plan on taking it to the shop to match it up and work on replacing.
Thanks again.
natural gasser
EVO
May 7, 2017 07:01 PM
theyammieguy
Exhaust System Topics
Dec 2, 2011 08:12 PM
chitown
May 5, 2010 10:19 AM
tc
EVO
Jul 25, 2009 08:50 PM
Wally
Sep 1, 2006 01:24 AM
