Four Speed
Old Mar 19, 2015 | 07:08 AM
Rob85WG's Avatar
Rob85WG
It happened to me. I was removing the clutch to replace the inner primary seal. The aluminum posts broke off while removing the hub because the hub was seized on the shaft due to spinning. I even broke my indy's hub puller because it was on so tight. I replaced the hub with a steel oem unit. The factory upgraded the design to steel. I was told not to use loctight because I may have trouble removing the hub again (if I had to). With a steel hub, the proper torque on the hub nut, and no more burnouts it shouldn't happen again.
The PO must have beat on my bike after he built the motor up. (stroke, bore, and cam)
Old Mar 19, 2015 | 12:50 PM
pjb's Avatar
pjb
The aluminum clutch hubs are known to crack in the keyway also. Years ago, the good folks at Zippers installed a reinforcing collar on mine.
Old Mar 19, 2015 | 05:01 PM
glidein wide's Avatar
glidein wide
Got a Barnett set-up, not sure if it's steel, good question probably not. I've heard of people using impacts on the hub and splitting it like a log. Knowing this **** does save the rear tire.......,somewhat.
Fabian Prell
Screamin Eagle CVO Models
13
Apr 1, 2019 09:44 AM
carpentercb
Jun 28, 2015 08:20 AM
dylistn
Jun 16, 2015 08:52 PM
Skeezmachine
Jan 21, 2012 11:43 AM
ioncat14
Jul 17, 2009 09:43 PM
