shifter cam dowels
Old Apr 1, 2015 | 06:43 PM
RidemyEVO's Avatar
RidemyEVO
Default shifter cam dowels
Tranny is back in the bike and was adjusting the shifter pawl attempting to use a 3/64 drill bit to get the shifter pawl even for the gapping. I know the service manual shows to use only 2 dowels on the carb side of the tranny for the shifter arms and I noticed with the shifter cam supports snugged down to the tranny that as I attempt to setup the shifter pawl to the pegs on the end of the shifter cam moving back and forth that the entire shifter cam slides a bit on the pawl end. I know that the shifter cam is not torqued down but was wondering do you guys that deal with this alot even add the 2 dowels on the pawl end supports? The supports on both ends have the cutouts for the dowls so why not use 4 dowels rather than the 2?
Old Apr 1, 2015 | 08:27 PM
D_gyver's Avatar
D_gyver
I think your book is wrong its the 2 front dowels one on each block with the slot facing forward
and if you look at the parts breakdown it says you need 4 dowels part number 609
I always try to put all 4 in I torque the drum down before I install the forks if it spins freely your good if not you will have to remove one or both of the rear ones to un bind the bearings
Old Apr 2, 2015 | 03:40 AM
RidemyEVO's Avatar
RidemyEVO
May be missing something here, both my service manuals show only 2 dowels, I will recheck though.
e11charlie
Jul 2, 2020 06:48 AM
divehard
Shovelhead
Aug 3, 2012 07:30 PM
jm1211
Feb 2, 2009 10:45 AM
JacktheBagger
Oct 2, 2008 09:21 PM
