Diy camgear change
Old Apr 18, 2015 | 12:31 PM
insp.clouseau's Avatar
insp.clouseau
Default Diy camgear change
Hi guys
Just finished a cam change for a buddy after swapping mine last winter.
While mine doesn't have a whine AT ALL, his one does sing a little.
So..have to swap with original gears this time.
But.... Unfortunatly I dont have immediate acces to a press.
I have read on this forum that it is possible to remove/install the gear mannualy by putting it in the freezer.
Can anyone ellaborate on this technique and do I have other options?
Thx a lot and keep the rubber side down ;-)
Old Apr 18, 2015 | 01:22 PM
Dr.Hess's Avatar
Dr.Hess
Well, the theory is that you would freeze the cam and put the gear in the oven at say, 200F or 250 or so, then when you put the pieces together, they will slide right together and stick when one expands and the other contracts. I dunno about getting them apart. A BFH may do it.
I think you would be a lot better off just taking it to someone with a press. They won't charge you much.
Old Apr 18, 2015 | 02:02 PM
br549A1's Avatar
br549A1
Google stuff like "oven gear cam" you'll get plenty of links on how. Here's one below.
If you plan to do this, make sure you mark the gear so that you'll be able to see the mark and keyway on the cam in whatever position you'll need it in. It's going to be hot, you aren't going to be holding it or fiddling with it. You'll have to have some blocks set up to put the gear on and slip the cam in.
You have seconds to get it in line and slap it together. Once it locks up its not moving. I'm not sure how you plan on getting the gear off without a press. A hammer is going to damage the new cam. I tried this only because I had access to a press, but had to wait a week. I figured nothing to lose. Well it worked only halfway, it slid on like butter halfway then locked up. It ended up helping me come press time because I had it lined up just needed the press to get it the last half inch. I didn't have to fumble with the alignment, just slapped it on the press and cranked it down. I'm not sure if you get stuck you could use a torch on the gear to get it moving.
My advice, find a press, it will take you less time and if it's not aligned you can redo it. I'm all for diy and will try anything to avoid help but this is just a pain in the *** and a press is very easy. You want to diy this build a diy press out of wood , threaded rod and a bottle jack
http://www.competitiondiesel.com/for...p/t-47288.html
Old Apr 18, 2015 | 02:18 PM
Dr.Hess's Avatar
Dr.Hess
$199 less 20% with a coupon, and you'll wonder how you got along so long without one.
http://www.harborfreight.com/20-ton-...ess-60603.html
Old Apr 18, 2015 | 04:03 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by insp.clouseau
Hi guys
FWIW when I changed my cam (before I got on the forum) I had a whine and was told to ignore it and it would go away with in 5k miles.
It did go away and that was 35k miles ago.
Old Apr 18, 2015 | 04:10 PM
insp.clouseau
Thx for the info guys,
Any idea of how much pressure the press should be able to produce?
Might just try to conjure up such apparel with some wood But I dont have any hard oak left.
Old Apr 18, 2015 | 05:37 PM
Tee&Vee's Avatar
Tee&Vee
Didn't the user HarDlife start a thread about this last year? I think it was the method the good doctor prescribed er described.
Old Apr 18, 2015 | 10:00 PM
apples402's Avatar
apples402
Tried the BFH on my old cam, didn't work....used two pieces of oak 6x6 and beat away...maybe moved it about 1/8 inch wasn't about to try this with the new cam. Press took about 5 minutes off and on and the shop did it for free because it was a learning experience for them.
Old Apr 19, 2015 | 04:29 PM
insp.clouseau
Thumbs up
Yup...shop - press it is than....
Thx again for the info guys.
If it wasn't for the good people on this forum, I would have given up on decent EVO's and joined twinkie town.
Enjoy the ride folks ;-)
Road Star
Engine Mechanical Topics
Jul 28, 2017 08:23 PM
rainsong
EVO
23
May 3, 2017 01:50 PM
TStephen
Dec 2, 2016 01:25 PM
terrapin88
EVO
42
Apr 17, 2013 07:39 PM
riden2low
EVO
Apr 13, 2007 02:23 AM
