No balls!
Old May 12, 2015 | 03:44 PM
  #51
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by flhchaz
I hope it works out tonight. I'm ready to ride more and wrench less!
I know what you mean.
I finally got the new tire and new break pads on the FXST.
And put it on the ground ready to ride!!!
I just checked the weather and it is gonna rain until further notice!!!!
Old May 12, 2015 | 04:00 PM
  #52
flhchaz's Avatar
flhchaz
As luck would have it!
Old May 12, 2015 | 09:03 PM
  #53
flhchaz's Avatar
flhchaz
bummer! Verified the timing and the carb already had a 295 and 70 I put a 72 main while I had it apart. I'm now thinking something is wrong with the way that I wired it. I have the ign and coil powered by the white wire with the black trace that is switched with the run/stop handle bar switch. I'm thinking that it may not be giving either the ign or coil the proper power. Back to the fsm ....I guess
Old May 12, 2015 | 09:11 PM
  #54
texashillcountry
Dirt don't hurt
Did you turn the VOES on?????
Old May 12, 2015 | 09:13 PM
  #55
Dr.Hess's Avatar
Dr.Hess
You just need to tune it. You went with some type of aftermarket ignition, right? Is it adjustable? That is, is there a slightly more aggressive curve? Try that. And like I said, change one jet, ride it, keep notes, change it the other way, etc. Takes time. Or bring it to a tuner guy with a dyno and pay.
Old May 12, 2015 | 09:14 PM
  #56
johnjzjz's Avatar
johnjzjz
take a picture of the ignition as it sits in the cone and post it
what is the switch location on and off starting with the first or do 2 pictures and that one a close up
Old May 12, 2015 | 09:17 PM
  #57
flhchaz's Avatar
flhchaz
I'll post some pics tomorrow night
Old May 12, 2015 | 09:18 PM
  #58
flhchaz's Avatar
flhchaz
Voes is on
Old May 12, 2015 | 10:08 PM
  #59
Tee&Vee's Avatar
Tee&Vee
Dr Hess, if the bike had more power with the enrichner on, would that lead you to believe that it needs more fuel?
c
The enrichener should be closed, no? Since it is more or less used in the same capacity as a choke I like to keep it open only to start the bike then completely closed. This is where fine tuning, especially the air mixture screw, comes in.
Tom
Old May 13, 2015 | 06:22 AM
  #60
flhchaz's Avatar
flhchaz
Tom
I agree to only use the enrichner to start the bike. I was using it to kind of troubleshoot the amount of fuel in the carb. I'll get after it again in the next few days and see what I can find, going to rain here anyway! on the bright side my '97 is running great!
