Evo questions
Old May 22, 2015 | 02:30 AM
Ipara's Avatar
Ipara
Question Evo questions
On my 91 FXRS it has a Screamin Eagle ignition module that has 8000 rpm printed on the top of it. Stupid question time... Does it mean the engine is allowed to rev up to 8K? If that's the case then what's the advantage in being able to do that? I would think it would cause engine problems at some point.
I'm sure this has been asked one or two thousand times before... What do you need to do in order to make the choke **** stay when you pull it out? I had problems even on my old 03 FXDL. It's really hard to warm up the bike when the **** wants to pull itself back in, unless you baby sit it, but then you can't get ready to ride if you do baby sit the choke.
Old May 22, 2015 | 04:04 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Question 1: Wither or not your ignition will let the motor rev to 8k there is no way I would try it.
Question 2: There is a plastic jam nut that you can tighten up (don't use a wrench as you will probably break it). You can find it just behind the choke ****.
FWIW I recommend starting your bike with the choke then rev it up a little with the throttle and use the throttle lock to keep it running. Disengage your choke when you rev up the throttle.
Old May 22, 2015 | 07:44 AM
JohnnyC's Avatar
JohnnyC
If your doesn't have the jam nut assembly behind the **** (be careful how tight you make this, on older setups they deteriorate and will break) you can use side cutters to put a crimp in the cable shield to add some retention to the cable.
Old May 22, 2015 | 08:47 AM
Dr.Hess's Avatar
Dr.Hess
The motor probably won't pull to 8K anyway. The valves will float before that, probably around 6. Best to keep an eye on things or have a good feel for it if your going to nail it, especially in a low gear.
Old May 22, 2015 | 10:12 AM
0maha's Avatar
0maha
Its taken a while for my '90 FXR and I to get to know each other, but that's exactly where I've ended up.
For a cold start: Petcock on. Pull choke. Two twists on the throttle to juice up the carb. 99% of the time she fires right off. Immediately but gently push in the choke while operating the throttle as needed to keep it running. Tighten down the throttle lock, keeping the engine at about 1500 or so.
By the time I've got my jacket, hat and gloves on, she will idle nicely.
Old May 22, 2015 | 10:13 AM
0maha's Avatar
0maha
As far as 8k goes, mine is pretty much out of smoke around 5k to 5.5k anyway, so I never rev it nearly that high. In day to day riding, it rarely sees 4k.
Old May 22, 2015 | 11:12 AM
Uncle G.'s Avatar
Uncle G.
That's just where the "rev limiter" is set on that particular ignition module, which, for most Evo engines, is like saying "no limiter".
Stock ignition modules had the rev limiter set at 5200 RPM IIRC.
Old May 22, 2015 | 01:15 PM
JohnnyC's Avatar
JohnnyC
I was used to 6K to 6.2K with my old EVO when really getting on it with the Crane Hi4E module.
Now I seem to keep hitting the limiter at about 5.2K on my Rushmore. Gonna have to adjust that!
Old May 22, 2015 | 05:13 PM
Spanners39's Avatar
Spanners39
8K rev limit is just a ***** extension, the money you would have to spend to get it to rev that high and not explode is pretty epic....what many people really don't get is that H-D know their motors, they designed them to do certain things and so it can get messy when you make that design "better" without the rest of the re-engineering that is required.
Old May 23, 2015 | 06:57 PM
Ipara's Avatar
Ipara
FYI, I would never want to rev the engine anywhere near the red line if I can help it... I'll use the throttle lock, never thought of that... LOL
Bookie
Nov 23, 2015 08:43 PM
Texas_Rider11B
Carburetor Related
Jun 8, 2014 08:18 PM
HubrisHCC
Jan 13, 2013 01:17 AM
SneakyPete
EVO
11
Aug 1, 2011 06:33 AM
HarleyNation
Apr 9, 2011 01:26 PM
