Shift Linkage
Old Jun 29, 2015 | 11:23 AM
splattttttt's Avatar
splattttttt
Thanks to Lucky Luke linking this thread from one specifically pertaining to a "shift linkage mod" which in it self has proved to be a great DIY'er and I can see this one may prove just as valuble
Old Jul 3, 2015 | 10:06 PM
Crashone's Avatar
Crashone
Bought a new shifter shaft and bushings to install. I found some of the slop when I tried to take the heel shifter loose to change out, the bolt had been buggered up and the alan key was stripped out. I has to use a small cold chisel and tap it loose to get it off. I installed the new shaft and a new shifter bolt and set things tight. All is crisp and clean shifting now. Thanks for the help.
monkey sammich
Jun 15, 2021 12:20 AM
jeremy2854
Jul 28, 2013 07:21 PM
Hoblick
Aug 29, 2011 09:32 AM
Mcook7373
Aug 12, 2011 08:26 AM
DocHarley
Dec 23, 2008 07:21 AM
