Ultima Engine Bummer
Thanks in advance
The big engine finished the season strong, pulling back the compression made it start easier and tamed down some heat, runs smooth in normal conditions but still has a giddy up button.
That Rivera clutch is the catazz, clutch pull is less that stock, hasn't slipped one time pulling a big bike and donut eating rider.
Have a Baker trans but don't thrash it, have stayed away from throttle whacks and power shifts, don't need either with the torque of a big engine. Have a Screamin Eagle side car drive belt but still try not to test it. Did a couple of whacks with one of them cool with the front wheel lifting and the other ruined underwear, left it alone since.
The Ultima R1 with a Tjet is supplying all the fuel needed, have the AFR's on the rich side in WOT and AFR's numbers stay consistent, believe the Pingel helps also, no pump needed.
Yes brakes are VERY important when pushing a big bike past it's designed areas!
What changes have you made? you may need to wear a adult diaper when you run 3 gears
Hey Merry Christmas. And thanks for the help
I'll look up the number for the clutch and have the middle of the road ring gear set up, one ratio above the 66 tooth. It was also a Rivera product and was in the stroker motor before the big one, has held up well.
Sachs said the Ultima heads are bottle necked some and can release more power, he had my ports on the original heads opened up after looking at the new set of heads, really hit hard but was on the peaky side.
